Trying to fool the TPM sensors
Discussion in 'Gen 3 Prius Technical Discussion' started by Malosos, Oct 31, 2018.
  1. Malosos
    Malosos Member
    117
    33
    Los Angeles
    Anyone attempt this recently, was trying to use the method below on my 2010 since the new wheels I got don't have sensors and was never a fan of that annoying light anyway.
    Tried jumping as described below but had no success, any advise or am I doing something wrong?
  2. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Not sure on that jumper trick.
    I have a trick I am using but requires you have 4 working TPMS units. Physical pressure causes a reading so I have one in my glove compartment in a binder clip.
  3. Malosos
    Malosos Member
    117
    33
    Los Angeles
    If your doing that on your 06 don't think itll work on a 3rd gen.
  4. Mendel Leisk
    42,275
    Do you guys need that light out to pass an inspection? Otherwise, I would just ignore it. And check your tire pressures regularly, of course.
  5. Malosos
    Malosos Member
    117
    33
    Los Angeles
    No, not for inspection it's to preserve what little sanity I have left and don't wanna tape over it knowing that little bastard is still on.
    My new wheels don't have sensors btw.
  6. Mendel Leisk
    42,275
    Meh, I'm tough, look at the baleful glare of the TPMS warning all winter long, don't bat an eye.
    Malosos likes this.
  7. Malosos
    Malosos Member
    117
    33
    Los Angeles
    Finally got it right thanks to some help from other members, here's how it should look... IMG_8159.jpg
    kenmce likes this.
