Trying to install heated seat kit to lower gear shift console
Discussion in 'Gen 3 Prius Accessories and Modifications' started by us_matrix, Apr 9, 2011.
  1. us_matrix
    us_matrix Member
    110
    I got Gen III base model. I bought heated seat kit off from ebay and planning to install it under Clazzio seat cover. I searched around and found that there is heated seat swtich under the gear shift 12v console. Does anyone has the wiring diagram and how to install after market heated seat kit? The kit i got just required 12v power. I am not sure if I should just get 12v power from the 12v outlet under the gear shift console or connect to the factory heated seat switch somehow.
    Thanks.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    Here it is.
  3. us_matrix
    us_matrix Member
    110
    Thanks.
    Where is the heater switch located? Is it located behind the 12v power outlet from lower center console from picture below? Do you or anyone has instructions of how to remove the lower center console area and wire diagarm behind the 12v outlet? I am trying to install the heated seat switch button in the 12v outlet area and may be just getting power from the 12v outlet if factory heated switch is not an easy task to do.
    Thanks again.
  4. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    The factory installed seat heater switch goes in place of the blank next to the power port. It's a combo switch, left and right in one assembly. I mounted the individual switches in the upper corners to the left and right of the blank and the power port within that same panel.
  5. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
  6. us_matrix
    us_matrix Member
    110
    Thanks Paul & Frodoz!
    Hi Frodoz,
    This is the one i got from ebay with the Hi/Lo swtich button like yours.
    Universal Heated Pad Kit Seat Heater Car (2 seat Kit) | eBay
    How/Where did you get power for the heated seat kit? Or did you connect directly to the factory heated switch behind the 12V outlet lower console panel?
    Thanks.
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Can't you find a more convenient place for the switch? Toyota's location is a stretch for me.
  8. frodoz737
    4,297
    2,348
    33
    My negotiated purchase was for a Model II Base with the Dealer's local installer to add full leather and seat heaters. Port installed leather did not include door panels and console. Without pulling panels I can not be sure where they tapped power. This is a common upgrade for Trim Shops, so the info is there, I just don't know. Sorry.
    You might consider doing the Lumbars as well, as these seats need a little help in that area. Then again, maybe I'm just getting old.
  9. mainemanx
    mainemanx Member
    355
    40
    State O' Maine
    There's also the pdf from the OP on this Yaris thread:
    DIY: Heated Seats for 2006-2011 Yaris
    You'll have to register first, but it's a generally helpful site... of course it doesn't really compare to our dear PriusChat. :)
    dh5379 likes this.
