TSB: Coolant leakage at front exhaust pipe (Prius & Prius Prime)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elektroingenieur, Nov 2, 2019.
  1. Mr.Vanvandenburg
    1,353
    571
    2020 Prius Prime
    It’s the employees. I just got off the phone with Amazon pharmacy. They said I don’t have an account. I said I have the bottle of pills from you in my hand. They said you need to create a new account, I can walk you through it. I asked if I can order the pills by phone without internet. They said no you can’t. My insurance switched this year to Amazon pharmacy. I’ll be switching back to a regular drug store pharmacy asap. It’s nuts.
  2. Mendel Leisk
    41,479
    Brazil…
  3. Kristen C.
    Kristen C. New Member
    Las vegas
    Yes bought in cali
    atterbury90 likes this.
  4. CA Guy
    CA Guy Junior Member
    24
    Three Touring
    The dealer still has not contacted me about the parts. I am thinking about doing the bypass while waiting for the parts.
    Questions:
    1) How hard is it to perform the bypass near the wiper cowl?
    2) If and when the parts arrives, how easy is it to reverse the bypass?
    Thanks!
    #44 CA Guy, Feb 16, 2025
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,161
    6,316
    Texas Hill Country
    Easy on both
    Top of engine bypass using existing temp sensor fitting and no hose
    CA Guy likes this.
  6. Mendel Leisk
    41,479
    Never done this (have a 3rd gen), but here's a video on the procedure, fwiw. I've set the link to start at the procedure:
    See @rjparker beat me to it, but still some value, above link fast-forwards to the procedure.
    luckyluk83 and CA Guy like this.
  7. CA Guy
    24
    Three Touring
    Thanks rjparker and Mendel! Really appreciated it.
    That does not look too challenging.
  8. Mendel Leisk
    41,479
    Hopefully gasket master's fix is effective and no ramifications. I seem to recall someone pointing out some side-effect, not sure how trivial how crucial. Something more than slower warm-up?? Mighta been @ChapmanF? Anyway, maybe he could comment.
    (Editorial: the Puzzling Professor was on CBC radio's North-By-Northwest this morning, discussing linguistic oddities, specifically compound words, hyphens and so on. I think I've caught the bug...)
    CA Guy likes this.
  9. CA Guy
    24
    Three Touring
    #49 CA Guy, Feb 16, 2025
  10. Mendel Leisk
    41,479
    Very likely will need to, if similar to gen 3.
    Yeah looking at your attached pdf, you do.
    Oh heck, not sure. :ROFLMAO:
    #50 Mendel Leisk, Feb 16, 2025
    CA Guy likes this.
  11. CA Guy
    24
    Three Touring
    Another question. Do I need to cap the bypassed pipe and hose? Or do I just leave them open? I need to undo the bypass when the dealer parts arrive, so I am concerned about possible foreign matter getting into the circuit.
    If I do need to cap it, how do I cap it? Thanks!
  12. Mendel Leisk
    41,479
    I'd measure the inside diameter(s) and obtain appropriate rubber stoppers. Just pushing them in firmly should do, there's no internal pressure. Or even just wadded rag and tape in a pinch.
    CA Guy likes this.
  13. ISFdude
    ISFdude Junior Member
    Queens New York
    Welp guys. Yes you can bypass the heat exchanger if you have over 150k miles or the car is older than 180 months old. But it seems we have another problem with just about all 2016-2022 engines. I’ve seen more than enough headgasket failure to know it goes out in the same area like the 2010-2011 Prius engines did. My own Prius with 83k miles is leaking coolant on cylinder 1 and the spot it’s coming from is the same where it is with many that are coming in to be repaired. The coolant is too aggressive I told Toyota. It kills plastics and eats away at gaskets. Lexus is have the same problem as well.
  14. Jayw100
    Jayw100 New Member
    Four Touring
    Hi guys, when it comes to the bypass does it cause a check engine light to appear? I just finished, and now I have a light on. I don’t mind it, as long as I know it’s related to the bypass.
  15. Brian1954
    Brian1954 Senior Member
    2,220
    874
    South Central PA, USA
    No, the bypass should not cause the check engine light to come on. You need to scan the car for trouble codes.
  16. luckyluk83
    luckyluk83 Junior Member
    UK
    Excel
    I've just done the bypass in my Prius 2016 (220k miles). I only drove for an hour and noticed that coolant stays about 10-15 C cooler than before. I do monitor that through an app. I will do that for the next few days and post how it is. At the moment in UK it is relatively cold so it is perfect time for testing.
  17. UN4GTBL
    UN4GTBL Junior Member
    Technology
    Last week, we had the CEL come on in our Prius on my wife's way home. P01511, P148F00, P012800 & had very low coolant.
    I went to the dealer to get some coolant, and while I was there I talked to a service advisor who was able to confirm that there was still ~2 months of emissions warranty left on our car. I booked it in for the next day. I came home, topped up the coolant, and didn't think much more of it, until I checked the car later and discovered the coolant had all leaked out of it again.
    I topped up the coolant before I slowly drove it to the dealer the next day, only to see that the CEL had cleared itself lol
    I talked to the service advisor at the end of the day, and he told me that they were able to confirm that it was the faulty front exhaust pipe, AND there was a few of the new part sitting in the local PDC!
    Next day, around lunch, I had a call that it was all good to go, fully covered under warranty.
    The mention of head gaskets above has me a little worried however.
