TSB on Excessive Oil Consumption for 2ZR-FXE Engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusplus_fr, Aug 16, 2018.
  1. priusplus_fr
    priusplus_fr Junior Member
    29
    23
    France
    2012 Prius+ MPV
    Interesting post from Toyota Headquarters: 2010-2014 Prius Excessive Oil Consumption on 2ZR-FXE Engine
    Interesting point: the problem comes from the piston and the piston rings (worn rings).
    Does it mean Toyota know about the issue?
    This article "Toyota Prius Problems and Common Complaints" also point out that this problem is also true for other Prius models. Only TSB have been released for 2ZR-FXE engines:
    Here are the two files for diagnosis and repair for excessive oil consumption (replace piston/ piston rings).
    If you have other way to restore/clean piston rings and pistons, let me know.
    52,785
    yes, thank you! nice that they finally figured it out before the 15's.:rolleyes:
  3. priusplus_fr
    29
    23
    France
    2012 Prius+ MPV
    The first TSB has been released on November 16, 2016...
  4. Mendel Leisk
    42,274
    According to TSB-2, the oil consumption criteria is one US quart per 1100~1300 miles.
    This is much less, slightly less than 50% of the consumption requirement: 1.1 US quart per 600 miles specified in the Owner's Manual.
    What is a Technical Service Bulletin exactly. I get the impression it's a notice of potential trouble from Toyota, but one that is not "broadcast", not a a recall. Dealership service departments are notified of the issue, but only initiate the actions in the bulletin as a last resort, if pushed, whatever.
    I'm a little incredulous too: can't imagine a dealership taking on a soup-to-nuts engine rebuild. Would they do this, or talk to Toyota, bring in a new engine?
    #4 Mendel Leisk, Aug 16, 2018
  5. priusplus_fr
    29
    23
    France
    2012 Prius+ MPV
    Dealerships are asked to only do the repair if under warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle’s in-service date." But according to some users, this problem might start around 100 000 miles or more.
    Preeeus and Mendel Leisk like this.
  6. ITBland
    ITBland Active Member
    433
    278
    New Orleans, La area, US
    From the Toyota FAQ: What is a Technical Service Bulletin and how is it obtained?
    (but might announce one!)
    #6 ITBland, Aug 16, 2018
  7. bisco
    52,785
    pointless really, but they must have their reasons.:rolleyes: usually it's when they have had enough complaints from the dealers about items that aren't always obvious, but are happening frequently under warranty.
    so a customer comes in complaining about oil loss while under warranty, well, here's your tsb. otherwise, it can be a hassle to prove it.
  8. Tideland Prius
    16,673
    Also TSB are minor, non-safety-related stuff.
    Sometimes they are required, (like our 2002 Camry's TSB for the washer fluid sensor - it was missing a hole in the buoy inside the tank so it won't read the fluid level correctly) so in that case, it was taken care of immediately.
  9. alanwagen
    alanwagen Member
    122
    79
    FORT WORTH
    2018 Prius
    Sort of weird that some do and some don't burn oil.
    I have done all synthetic changes at the dealer. I have 94k and no problems yet, but does that mean I will with my 2010 Prius?
    Raytheeagle likes this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Probably at some point ;).
    But if you check your oil level often, you’ll catch it before it becomes a real problem :).
    A 2 minute job that saves headaches (y).
    ASRDogman, RMB and Grit like this.
  11. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Keyword is dealer. If done every 5k and they actually put in the correct oil type, weight and amount you’ll won’t experience it soon.
    Also There’s no guarantee even if you’re up top of engine oil maintenance on any cars.
  12. prince
    prince Junior Member
    52
    17
    Atlanta, GA
    Sorry for bringing this back up but found it in a search. Mine has 145k now, did the oil change at 140k and just started getting the oil low warning flashing every 100 miles or so. Took it to the dealer and the oil was gone, they topped it up and they mentioned this 1300 mile test so started that today. Anyone else have experience with this?
    Preeeus likes this.
  13. Mendel Leisk
    42,274
    The warning is low oil pressure. They probably needed to "top it up" four quarts. Did they say?
    Considering your consumption to be 4 quarts in 5k miles, if you take it back just before 1300 miles, you may qualify.
  14. prince
    52
    17
    Atlanta, GA
    Even so, my car is out of warranty and they won't cover right?
    Preeeus likes this.
  15. Mendel Leisk
    42,274
    I can post the TSB's when I get home. Was it 60k limit, maybe. But considering they want to DO the test, that seems a BIG positive. Maybe Toyo is quietly authorizing more than they say officially? Go through with it for sure.
    Maybe ask them, regarding the warranty?
    Do the occasional full throttle hill climb... :whistle:
    Tande likes this.
  16. Mendel Leisk
    42,274
    TSB's:
  17. Haschwalt
    Haschwalt Member
    110
    35
    New York
    So from what I understand the P/Ns were released in 2014, but Toyota didn't actually install these until the 2015? This suggests that the 2015 should be the Prius to buy no? Usually the last year of a model will have the least amount of flaws given the amount of time to collect data points on that model.
  18. Mendel Leisk
    42,274
    Asking for pistons and piston rings for various years, at McGeorge Toyota Parts website, this is what I got:
    The pistons were revised in model year 2014, and the rings as well in 2015. The efficacy of the revised parts to reduce oil consumption is still a question?
    Neural Net and Haschwalt like this.
  19. Preeeus
    Preeeus Member
    258
    60
    Did you ever get any help from Toyota paying for all the required expensive repairs after failing their test?
    Our vehicle failed Toyota's own test, but Toyota was not willing to help in any way whatsoever.
  20. Mendel Leisk
    42,274
    Their cut-off is 60k miles? Which is pretty bald; the oil consumption usually starts later, say after 100k.
    cyclopathic likes this.
