TSB on Excessive Oil Consumption for 2ZR-FXE Engine
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by priusplus_fr, Aug 16, 2018.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Mine started consuming ~220k and got really bad at 250. Went down after seafoam piston soak but it is still a quart per 3200mi in long distance, will probably be half in local short trip cycle.
  2. johnHRP
    johnHRP Active Member
    646
    189
    KA, DE
    Excel
    If you do 5000 miles /6 months oil change interval, you less likely has any oil consumption issue. But you consume 2x more oil than the normal schedule.
    Lets calculate how much in 200k miles, typical Prius owner keep their car for.
    In 10 years/200k miles, we add about 20 gallons more oil or about $500 more, but you safe the catalytic converter and the engine from burning 1 quart per 1000 miles. Let say, after 100k miles, others have 1 quart per 1000 miles burning oil issue. It is about 100 quarts or 25 gallons=$625 in the next 100k miles in 5 years, they burn more money than you do by changing the oil every 5k miles.
  3. cyclopathic
    3,292
    547
    2014 Prius c
    It isn't as simple as you describe; burning oil causes carbon deposits, catalytic converter blockage, misfire and excessive engine wear (bores, bearings, etc).. not counting that it is bad for environment.
    There's a class action lawsuit against Toyota going on, FYI
    Toyota Oil Consumption Defect Lawsuit - Car Attorney
    BTW the replacement oil rings are taller, 2mm vs 1.5, FYI
  4. Mendel Leisk
    42,341
    Also more outward springiness (aka tension), I’d speculate.
  5. cyclopathic
    3,292
    547
    2014 Prius c
    Hard to tell from internet description.. maybe someone who held them in hand jives in? I doubt there's much difference as they are designed for thinner 0W20 oil, stronger ring will leave no oil film behind.
    I hope they've gone back to 3 piece oil ring design vs 1-piece.. additional flex helped to break apart carbon deposits.
  6. ASRDogman
    ASRDogman Senior Member
    8,063
    4,086
    That law suit does not include the Prius....
    #26 ASRDogman, Jul 19, 2021
    Grit likes this.
  7. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    bam! Just like the white paint peeling, prius are also sol’d.
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I don’t understand these lawsuits.
    Cars come with warranties. Everybody knows that cars come with warranties. Everybody knows that means, if it breaks outside the warranty period, it’s your problem. You can only go on manufacturer reputation at that point.
    If your engine throws a rod outside of warranty, boo hoo, shut up and go fix it. I don’t understand why people can sue for the obvious: The car doesn’t have to keep working after warranty.
  9. ASRDogman
    8,063
    4,086
    I just said the lawsuit doesn't include the Prius!!!
  10. cyclopathic
    3,292
    547
    2014 Prius c
    Let me explain if you're slow and don't understand :
    Car has mfg/design defect which Toyota had recognized and even issued TSB. This is an equivalent of you knowingly selling a defective product, which is causing harm (to environment). This is no different to recalls issued due to defective catalytic converters, ECU programming or defective emission system; has nothing to do with warranty.
    For everyone else: TSB expired 3 years ago and Toyota HQ refuses to own the issue, they've basically told to go ef yourself. I would still recommend to call and log complain with NHTSA and Toyota.
    Personally I doubt I will ever buy another Toyota; not because they made a mistake but because they refuse to own it.
    EDIT:
    NHTSA # (877)923-4454
    Toyota # (800)331-4331
    #30 cyclopathic, Jul 21, 2021
  11. ASRDogman
    8,063
    4,086
    So how long should a manufacturer "own" up to something?
    1 year? 2? 5? 10? 20???
    Even with a house you only get 1 year.
    If you're not happy with Toyota, you could buy a yugo, or ford, or chrysler, or any other brand.
    NO one is forcing you to buy a Toyota.
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    forever!!!
  13. Mendel Leisk
    42,341
    There's the rub: complacency and dodging issues is the norm, with every one of 'em...
  14. cyclopathic
    3,292
    547
    2014 Prius c
    Ask Volkswagen. IIRC they went ~15 years back.
    All I know oil consumption on 2ZR-FE/FXE and 2AZ-xxx is due to narrow single piece low tension oil ring design, previous engines with wider 3-piece rings didn't have this problem and when they did it was much easier to get them unstuck. Of cause location of PCV valve didn't help either, it causes small oil consumption which promotes stuck rings, and when that happens they're stuck for good.
    And 2ZR is absolute bear to work on; you need to pull engine out to get access to pistons. Toyota estimates 21-22hr/$2600 in labor just for that.
    And don't get me started on blown head gaskets so common on 2ZR-FXE. If you curious google "Prius head gasket".
    Aaron Vitolins likes this.
  15. cyclopathic
    3,292
    547
    2014 Prius c
    While this is certainly true Toyota had much more at stake to loose, their reputation.
    The problem is widespread GM, Hyundai, VW have this problem (thanks to rising mpg standards and switch to 0W20 oil), but at least VW had replaced rings without class action lawsuits. Toyota did recall Camry and Corolla, and only because there were more of them sold and more people joined on lawsuit.
    EDIT: it used to be "Toyota: we build boring but very reliable cars" now it is "we build sh!ty and boring cars"; case closed.
  16. Mendel Leisk
    42,341
    T-SB-0169-16 (Attached) says 16.6 hours, but yeah, who knows: it’s a big job.
  17. cyclopathic
    3,292
    547
    2014 Prius c
    There's a YouTube video of guys doing Gen3 engine swap in 57min in a parking lot; beats me how Toyota gets it done in 16hr.
    Problem is that even if you get a low mile JDM engine it's most likely gonna have the same pistons/rings.
  18. ASRDogman
    8,063
    4,086
    Well my 1978 Corolla frame bent when I get hit by an idiot driver!
    It's Toyota's fault for building such a weak frame! I want my money back!!!!
  19. johnHRP
    646
    189
    KA, DE
    Excel
    It is unfortunate for 2010-2012 Prius owners who have old version head gaskets.
    Fortunately, in 2015, Toyota redesigned the piston and piston rings at the same time. Almost no 2ZR-FXE engines after that year consume excessive oil. Even the 4th gen with 0W-16 oil. Most 2ZR-FXE engines pre-2015 consume certain degrees of engine oil at around 100 000 miles if they do 10k miles/1 year interval.
  20. Mendel Leisk
    42,341
    My take-away from that: Toyota screwed up. They went chasing n'th degree high mpg, throwing in everything, risking engine longevity. Likely for $’s.
    #40 Mendel Leisk, Jan 20, 2022
    cyclopathic likes this.
