TSLA in my hands
Discussion in 'Tesla' started by bwilson4web, Mar 5, 2019.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    After reading what @Trollbait and @DavidA wrote, I think they both make good points. If you already have a 40A circuit, you could just make sure the car doesn't draw more than 32A. But if I was needing to install a circuit, a 50A doesn't cost that much more. And since I could do it myself, I would probably upgrade a 40A to 50A to get the most out of the system. If you have to hire someone to do the upgrade, then that takes some extra motivation.
    Prodigyplace likes this.
  2. markabele
    5,084
    1,782
    Nebraska
    We should all just crownfund a big road trip for Jerry to come help all of us with electrical upgrades!
  3. Prodigyplace
    12,710
    11,848
    Central Virginia
    Thank you for your professional electrician view on this.
    jerrymildred likes this.
  4. jerrymildred
    11,517
    14,164
    Tampa, FL
    Just saying what I would do. ;) Previous posters had it covered pretty well.
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    Some people were questioning the 20% headroom circuit buffer.
  6. Trollbait
    12,806
    I would do this myself, if the faster draw wasn't needed to cover daily driving use. The question I have is, would such a set up need to be 'fixed' before home renovations or selling?
    The max amperage draw of an appliance can vary a little from what the label states. Likewise, the breaker could be tripped at lower than stated. So the closer expected appliance draw to the breaker rating, the more likely of the breaker tripping.
    Then there is a fire concern for the wiring. Pulling 39 amps continuously on a 40 amp circuit will heat up the wiring more than on a 50 amp circuit. The entire reason for fuses and breakers in a home is because a fire will start if a wire is carrying more amperage than it is rated for.
    jerrymildred and Prodigyplace like this.
  7. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Thanks Jerry, this is consistent with my understanding. I installed a 50A breaker for my UMC (Universal Wall Connector) with a NEMA 14-50 outlet, even though my model 3 can only draw 32A with this connection, by design. The reason I did this is because the cost of materials was only about $10 more than a 40A circuit AND I wanted the flexibility of a larger circuit if needed in the future with Tesla upgrades. My car charges very happily on this 32A system at the rate of about 30 m/h. If my car was capable of charging at 40A, it would charge at about 37 m/h. But that is a moot point because I usually need way less than 100 mile recharge per day which means only 2 to 3 hours of charging at night under either system.
    #27 el Crucero, Mar 8, 2019
  8. Prodigyplace
    12,710
    11,848
    Central Virginia
    I agree. I just thought a licensed electrician chiming in would add credibility to the discussion.
  9. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Even more important is that a 40 amp breaker "might" only be accurate to within 5% (I don't know what the actual code says about tolerances). So it might not trip until 42 amps. And a 39 or 40 amp device might not draw exactly that and might consume 41 amps, for example. So your whole end-to-end wiring could be over current, continuously.
    The required standard wires sizes are supposed to account for a combination of tolerances that are at the edges, I would think. But still not a good idea to test it.
    Mike
  10. jerrymildred
    11,517
    14,164
    Tampa, FL
    The size of the breaker is based on the ampacity of the wires. It's not to protect the load, but the wires. Otherwise you would be unsafe plugging in a night light in a 15 amp circuit.
    The general rule of thumb, to protect the breaker from failure or false trips, is to not put more than 80% of the tripping point amperage on that breaker.
    So, if the charging device is hard wired, you size the wires to carry that load plus a safety margin and then size the breaker so it will trip before the wires can overheat if something increases the current too much.
    But, just to be clear, I am not a licensed electrician. I have quite a few years of industrial electricity experience and was trained by some really smart guys in addition to the electronics degree. But no actual license.
  11. Prodigyplace
    12,710
    11,848
    Central Virginia
    Sorry. In my state you need to be a licensed electrician if you are paid for doing electrical work. I thought that was a widespread law.
  12. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    The EEs that design the circuit don’t have to be ;)
  13. jerrymildred
    11,517
    14,164
    Tampa, FL
    If you're a contractor, yes. In the manufacturing facilities, the employers are responsible. I could not legally go hire myself out to wire someone's house, but my former employer could hire me back to work again in one of their factories if they were crazy enough to hire someone my age and I was crazy enough to work that hard again. LOL! In fact, about 30 years ago, I did work at one of our plants in VA for six weeks helping with a major project there.
  14. bwilson4web
    16,513
    So this is how I'll benchmark our Standard Range Model 3:
    Code:
           trips                                       mi  drive total
    Brentwood_HSV                                      102 01:45 01:45
    HSV_Tupelo(super)_Memphis(super)_Hollywood         290 05:01 06:01
    Hollywood_Memphis(super)_Tishomingo(NEMA14-50)_HSV 275 05:09 07:39
                                             Total     667 11:55 15:25[/FONT]
    So I'll pickup the Standard Range Model 3 in Brentwood TN and drive home. There is a NEMA 14-50 along the route as well as a SuperCharger in Athens. With only 50 miles to the NEMA 14-50, the battery would still be in the taper range. Even the Athens SuperCharger will be close to the taper region. I don't learn anything with either. Once I get home, my JuiceBox Pro 40 will give charging metrics and determine if the maximum L2 charge rate is 32A or higher.
    The Huntsville to Tupelo SuperCharger, Memphis SuperCharger, and Hollywood casino will be deep, ~50%, into the battery. In theory, I could reach Memphis on one charge, it could close. The route to Memphis is a divided but not an Interstate route so modest speeds, no more than 65 mph, are likely. I might try the direct route after getting more 'seat time.' If the car predicts range well enough that I can count on seeing the extra miles, it could work.
    Returning to Huntsville via Memphis SuperCharger and stopping at the Tishomingo State Park, NEMA 14-50, offers a chance to sample a midway, L2 charge. This replicates the gap between Little Rock AR and Tulsa OK where there is only a 30A, L2 charging spot, 6 stations.
    This will let me get the range testing within the Tesla return policy:
    Return Policy | Tesla
    . . . If you have taken delivery of your vehicle without ever having taken a test or demo drive with us, we understand that you may want additional time to get to know your vehicle. In that case, you will have seven (7) calendar days after delivery to return your vehicle, subject to the terms and conditions of this policy.
    We will accept your vehicle for return if the vehicle:
    • Has an odometer mileage of less than 1,000 miles at the time of return;
    • Has a New Vehicle Limited Warranty for the vehicle that has not been voided;
    • Has not been the subject of any submission or application for any available incentives or perks;
    • Is in new condition, without damage or abnormal wear and tear; and
    • Has not been resold or transferred to any person or entity.
  15. el Crucero
    1,628
    699
    Inland Empire
    I believe the model 3SR is limited to 32A on L2 charger no matter what you do. I suspect trying to over-ride the on board systems could void the warranty and Tesla return policy. And Tesla will know because the car automatically uploads all the logs.
    I have tested my model 3MR on several longer road trips (300 mi. - 800 mi.) I find the on-board computer remaining range prediction (either percent or miles) to be accurate to within ~1%. The computer is constantly re-calibrating subject to current speed, terrain, and wind conditions. Obviously, the closer you get to your programmed destination, the more accurate it is. I have charged to as high as 100% (just minutes before leaving on a longer trip) to as low as 7% when returning home. I usually keep my charge at between 20% to 80% for daily use.
  16. bwilson4web
    16,513
    Using Google map, I took another look at the Huntsville-to-Memphis SuperCharger route staying on highway 72. It looks like:
    1. 202 mi of 220 mi range = 92% of range, 18 mi reserve
    2. 3:50 drive time ~= 52 mph average speed, estimated 300 mi range
    It makes sense to test a maximum range segment early. It will also help validate the mph vs range chart.
    For the return trip, I may do a hop to Tupelo SuperCharger and then home. I’ll skip enroute NEMA 14-50 testing as I have a full power 40A at 240VAC EVSE at home.
    #36 bwilson4web, Mar 13, 2019
  17. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    After viewing this video - Tesla Wall Connector vs. NEMA 15-40 - comparing a 50amp circuit to a Tesla Wall Connector on a 60amp circuit. The Tesla Wall Connector appeared more efficient.
  18. bwilson4web
    16,513
    There are some technically light details not found in the video. Specifically:
    • charger (EVSE) defines the maximum current - not the car. So the Tesla mobile connector is already derated to 30-32A. In contrast, my JuiceBox 40 Pro is limited to 40A. He did not test a JuiceBox 40 Pro.
    • the car charger is the second limit - our Prius Prime, ~3.3kW, our BMW i3-REx, ~7.2 kW. I won't know the Standard Range Model 3 until I get mine to test.
    It is a nice video BUT lacking technical details. If you'd like more technical details about the J1772, let me know.
  19. Trollbait
    12,806
    That is probably a reflection of the different design goals of the EVSE's.
    A NEMA 15-40 outlet will be using the portable EVSE that came with the car. it is going to get tossed around, dropped, possibly left out in the elements, plugged into circuits of questionable quality, etc. It needs a degree of robustness in order to be reliable. It also comes with every car, so cost is a factor.
    The Wall Connector will be wired to a dedicated circuit in a protected location, and has a hard shell giving better protection to its innards. That, and the higher price tag, justifies using more efficient components. Whereas for the portable one, maximum efficiency is below reliability and cost.
  20. DavidA
    2,349
    1,825
    Chicago western burbs
    I gave that video a firm thumbs down, mostly because he doesn't know the difference between a NEMA 14-50 and a NEMA 15-40. Hint: One of those doesn't exist, even though he mentioned it and printed it onto the video like, 15 or 40 times.
    All Teslas come with a J1772 to TESLA pass through converter. A M3 limits AC charging to 32A and 240v (except for the LR model which is 40A). A L2 home charger on a 40A circuit should do just fine vs. the 50A TESLA branded L2 hardwired charger, which is overkill for all 3's except the LR version.
    I'm interested in Bob's findings, as my eMotorWerks L2 is 40A 240v, same as his.
    #40 DavidA, Mar 14, 2019
