TSLA in my hands
Discussion in 'Tesla' started by bwilson4web, Mar 5, 2019.
  1. bisco
    52,692
    dang, i was hoping to pick up a nicely depreciated 3.:cool:
    Raytheeagle likes this.
  2. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Out of my cold, dead hands, you will! ;)
  3. 3PriusMike
    3,101
    2,421
    Silicon Valley
    What are you getting for roundtrip wh/mile (no heat and with)?
    Mike
  4. el Crucero
    1,628
    699
    Inland Empire
    The most economical way (lowest kW/mi) to keep yourself warm is to use the seat warmers rather than the a/c. In cold weather, I set the a/c to somewhere in the 50/60's and then use the seat warmer to do the rest. Settings will vary depending on local conditions.
  5. bwilson4web
    16,495
    I don't have that level of detail, yet. But I did capture this 'pre-conditioning' charge profile:
    We will soon run out of cold weather to measure preconditioning, warm-up overhead. However, I am interested in the problem.
  6. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Have you checked out the trip odometers yet. They automatically record the wh/mile. You get two rename-able trips plus one for teh current trip. (swipe right in the lower left of the screen. Swipe left to see tire pressures)
    Mike
    Raytheeagle and Prodigyplace like this.
  7. bwilson4web
    16,495
    Yes, I've used both and have a dash cam setup that 'looks over my shoulder.' I'm running down the battery so I can record the SuperCharger rates.
    Preliminary data indicates there is an inflection point at ~150-180 mi SOC when the rate of charging falls to a low rate. For cross country travel, I need to know the charge rate so I can calculate the block-to-block speed and trip time.
    3PriusMike likes this.
  8. Prodigyplace
    12,708
    11,847
    Central Virginia
    You need to update your drafting avatar. :D
    Tour profile needs updating too ;)
  9. markabele
    5,084
    1,782
    Nebraska
    Unfortunately you can't set the a/c below 60.
  10. markabele
    5,084
    1,782
    Nebraska
    I think this is obvious, but I will state it so no one can argue otherwise:
    Bob is doing this for research purposes. It doesn't take this research to drive a Tesla. In fact, I did 1200 miles in a day and half with no upfront research at all. The trip nav/computer did all the work for me.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Fixing my own post...just to be complete:
    There are two trip odometers that you can name (I made trip B = "Lifetime" and don't reset it)
    There is one for the current trip that resets when you shift into drive or reverse...after the door has been opened/closed.
    There is one since the last charge...obviously resets when you charge
    Mike
