Turn off lock/unlock beep
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Wandering Elf, Aug 18, 2015.
  1. Wandering Elf
    Wandering Elf Junior Member
    28
    Perth, Western Australia
    Hi everyone,
    just got a 2010 Prius (Australian base model), and looking for information on how to turn off the beeps when locking/unlocking the doors. I've found info on turning off the seat-belt warning beep, and changing the reversing beep to single by using the OBDII connector, but nothing on the CAN bus codes needed for the lock/unlock beeps.
    Or is there another way? (the dealer wants to charge $60 to do it)
    Any help appreciated.
    Dean
  2. DavidA
    2,349
    1,824
    Chicago western burbs
    I just press the lock/unlock rocker switch in the door right before I close the door when I am parking it. There is no beep when that is used for locking. For unlock I touch and pull the handle and I don't use the key fob button. Less battery wear and no beeping noise.
    Wandering Elf likes this.
  3. Wandering Elf
    28
    Thanks David for the tip about the rocker switch. I also just use the handle to unlock, but it still beeps/chimes.
    BTW I just successfully changed the reversing beep to just one beep using an ELM327 cable and the puTTY
    software on my windows PC. So there should also be a code sequence for the lock/unlock chime, since it also is a user
    customisable feature.
  4. bigmodernmess
    bigmodernmess New Member
    I have a '12 Prius Two and I think I saw in the Vehicle Settings screen that you can change the volume of the beep. I haven't tried it, but I bet you could disable it from there as well.
    The '10 might not have this setting page in the head unit though...
  5. bisco
    52,532
    if the dealer can do it, it must be through tech stream, which is available on amazon for $25. if you have an old windows laptop.
  6. DavidA
    2,349
    1,824
    My post above I was wrong: there is a beep when I grab the door handle to unlock (without the button on the fob). I guess I'm so used to the beep I don't even hear it anymore.
  7. Wandering Elf
    28
    Hi BigModernMess, Yes the 2009-2011 base model doesn't have a head unit screen like the 2012-on models (at least here in Australia), just a single line LCD display (I think). The manual says that these user customisable settings can be changed using a computer. Thanks to the good folk here at PriusChat, the code sequence for changing reverse beep is available. I'm guessing there must also be a code for the lock/unlock beep. Thanks Bisco, the Techstream software might be worth looking into, at least its cheaper than the dealer. No worries DavidA.
  8. Wandering Elf
    28
    Progress report:
    There seem to be some undocumented ecus at locations 712, 724, 7c6, and 784.
    ecu 7c6 seems to be the same as the Aircon ecu at 7c4 (except response to request 1a: read ecu id)
    ecus 712 and 784 don't seem to support any requests, but 724 responds to request 2701: security access level 1 with a seed.
    display ecu 7c0 memory mapping:
    2100 61 00 40 00 60 01
    2120 61 20 A0 80 00 01
    2140 61 40 00 00 00 01
    2160 61 60 00 00 00 01
    2180 61 80 00 00 00 01
    21a0 61 A0 82 10 00 01
    21c0 61 C0 00 00 00 01
    21e0 61 E0 C0 00 00 00
    2100 map 40 00 60 01 suggests location 02 should be supported, but 2102 request seems to fail (maybe need security access?)
    memory location a1 can be changed to 8 values: 00,08,10,18,20,28,30, and 38
    which suggests it could be "smart key operation signals (buzzers)" in user customisable settings, but
    no change to buzzer volume. Listed in PriusV codes as "Key Remind Sound"
    My cheap clone ELM327 v1.5 can access the main body gateway ecu 750 using:
    >AT CAF 0 (turn off automatic formatting)
    >AT SH 750 (set 11 bit CAN header to 0750)
    then example of access to a sub ecu:
    >40022131
    breakdown:
    40 = sub ecu number
    02 = number of bytes in request
    21 = read data request
    31 = the location
    response: 40 03 61 31 B4 00 00 00
    main body sub ecu 40 memory mapping
    40022100 00 e8 58 01
    40022120 00 00 f0 01
    40022140 00 00 06 01
    40022160 08 00 00 01
    40022180 00 00 00 01
    400221a0 FA 00 00 01
    400221c0 00 00 00 01
    400221e0 C0 00 00 06
    31 was the only location I could change using request 3b:
    >40033b31xx
    breakdown:
    40 = sub ecu number
    03 = number of bytes in request
    3b = write data request
    31 = location
    xx = any value from 00 to ff
    response:
    40 03 7F 3B 78 00 00 00 (78 = request pending)
    40 02 7B 31 00 00 00 00 (7B = request successful)
    smart key sub ecu b5 location 31 can also be changed:
    >b5033b31xx
    But neither of these changed the lock beep
    Seems that only need to push power button to ACC to access these sub-ecu's
    Any insights welcome
    cheers,
    Dean
  9. Wandering Elf
    28
    Found it.
    Turn car to acc on (ig on and ready should also work)
    Sequence:
    >AT CAF 0
    >AT SH 750
    >40063B14xx20
    where xx =
    8A flashers, no beep, both smart entry and remote can lock/unlock
    82 no flashers, no beep, both smart entry and remote can lock/unlock
    0A flashers, no beep, remote doesn't lock/unlock
    02 no flashers, no beep, remote doesn't lock/unlock (guess)
    I think there's more customisable settings to find, as locations 12 and 15 on sub ecu 40 can also be changed,
    also smart entry/smart key system can be turned off over at sub ecu b5 location b5:
    >b5043bb5xy
    where xy =
    2C turn off smart entry/smart key system (so must touch key to power button to start car)
    0C turn on smart entry/smart key system
    y can have values of 0,4,8, and C, but not sure what it does yet
    #9 Wandering Elf, Oct 15, 2015
  10. Wandering Elf
    28
    Just to clarify turning off lock/unlock beep (and other customisable features),
    here is a bit mask for location 14 of sub ecu 40 ("main body" ecu):
    >AT CAF 0
    >AT SH 750
    >40063B14wxyz
    w=0,1,8,9 x=0,2,8,A y=0,2 z=0,1,2,3
    1 remote unlock works (1=on, 0=off)
    1 beep on lock/unlock (1=on, 0=off)
    1 flashers on lock/unlock (1=on, 0=off)
    1 door open warning when locking (1=on, 0=off)
    1 panic button operation (1=on, 0=off)
    1 time to auto relock if no door opened after unlock
    1 (0=30sec, 1=60sec, 2=120sec, 3=60sec)
  11. DavidSpivey
    DavidSpivey Junior Member
    38
    United States
    When you finally work out all the hidden functions, please relay that information to Carista, as they offer an Android and iOS app to change settings through an ELM compatible device. I have already changed the lock sequence (unlocking all doors with the first remote press), extended the dome light timeout and adjusted beeps.
  12. Wandering Elf
    28
    Hi David,
    I checked the Carista website and they seem to already have all the customisable features I have found so far.
    My car already unlocks all doors at once - and there is no option to change this in my user manual. Maybe this
    is a difference between American Prii and Australian Prii. Extending the dome light timeout sounds like a great idea thanks.
    I found using:
    >AT CAF 0
    >AT SH 750
    >40063B12xyz0
    x = 0-F, y = 0 or 8, z = 0,2,4,6
    bitmask:
    1 lights time out (2 bits)
    1 00=15sec, 01=7.5sec, 10=30sec, 11=15sec
    1 interior + foot light on after power off (1=on,0=foot lights only if set below)
    1 lights on after door unlock (1=on,0=foot lights only if set below)
    1 lights on if smart key detected approaching vehicle (1=on, 0=off)
    1 faint drivers footlight when vehicle is in Drive (1=on, 0=off)
    1 footlights (1=0n,0=off) for both power off and unlock
    Originally I was 3860. For lights timeout extended to 30sec, I set to B860:
    >AT CAF 0
    >AT SH 750
    >40063B12B860
    cheers,
    Dean
    #12 Wandering Elf, Oct 18, 2015
  13. NedLlew
    NedLlew Junior Member
    oregon
    Hello Dan,
    Thank you for sharing this.
    I have an american 2015 Prius Two and wanted to turn off the lock/unlock beep. Your suggestions worked for me. Excellent - now the neighbors don't have to know when I am driving my car late at night.
    However, I attempted to set the auto-relock to 120 seconds, and the result is no auto-relock, it just stays unlocked. Which is fine with me for now. I haven't experimented with any other values yet.
    I did this:
    >at caf 0
    OK
    >at sh 750
    OK
    >40063b148a22
    40 02 7B 14 00 00 00 00
    -Ed
  14. Wandering Elf
    28
    Hi Ned,
    Glad you found the information useful.
    For the auto-relock, it maybe that there have been some changes in the programming between my 2010 model and your 2015 model (there was a minor update to the Prius in 2012), or that there were always differences between the U.S. Prius and the Australian Prius.
    ...or maybe I got it wrong, so if I get a chance I will try it on my Prius again.
    cheers,
    Dean
  15. pizzachef
    pizzachef Junior Member
    New Cumberland, PA
    2013 Prius v wagon
    Thanks again, this worked on a 2013 Prius V. I used code 8A to keep smart entry and remote, no beep, yes flashers.
    Its always a little nerve wracking typing cryptic codes into my phone when its connected to the car :)
  16. Ateeque
    Ateeque New Member
    Pakistan
    Dear Friends,
    Rather than turning off the lock/unlock buzzer through sfotware or settings, can anyone tell where the buzzer is located so it can be disconnected?
    Reagards
    Ateeque
  17. Wandering Elf
    28
    Sorry @NedLlew, I didn't get any more chances to look again at the Prius 2010. I now have a Prius C 2012, And I can confirm it works the same for Lock/unlock beep. I typed in (not including the '>' - thats the ELM327 command prompt):
    >AT CAF 0
    >AT SH 750
    >40022114
    40 06 61 14 9A 00 02 00
    >40063B148A000200
    >40022114
    40 06 61 14 8A 00 02 00
    So now the first byte has changed from 9A to 8A, and my doors lock/unlock with flashers no beep(s).
    You are welcome @pizzachef - so now it seems to work with all Gen3 models.
    @Ateeque, I think its not possible to disconnect bell/buzzer manually - it has many functions, and probably on
    some computer board.
  18. DavidA
    2,349
    1,824
    +1 about not disconnecting the beeper sound maker. The more important warnings it can give far outweigh the inconvenience of the lock beeps. Remember, it won't beep when locking if you use the button located on the doors.
  19. Soumya Sen
    Soumya Sen Junior Member
    India
    Technology
    The BCM is at CAN address 750 and gateway 40. The ECU replies at address 758 and gateway 40.
    So it will looks like this -
    Send to ECU - 750 40 01 3E
    Reply from ECU - 758 40 01 7E
    I tried applying your method to this problem (sending command via HyperTerminal to elm 327 device) like this -
    Try 1: Send to ECU - AT CAF 0, AT SH 750, 40 3E, AT CAF 1
    Reply from ECU - NO DATA
    Try 2:
    Send to ECU - AT CAF 0, AT SH 750, 40 01 3E, AT CAF 1
    Can you please help me where I am getting it wrong.
  20. testriderchuck
    testriderchuck New Member
    E washington
    NOT TRUE!!! The more important warnings.... except the normal beeps happen ALL THE TIME!!! EVERY TIME i START THE CAR IT BEEPS AT LEAST 5 TIMES! unlock, start, ready, bluetooth connected, and reverse. I've a seatbelt extender which stays plugged in or it'd be 6 beeps.
    Dont forget the panic-inducing, high-pitched fast beeping if you drive over a snow berm and the car gets a little squirrley/ slides around a bit. I'm probably a better driver than most but we still don't need so many D*** beeps. maybe if it were a voice, instead fo the same beep for everything.
    makes me wish for my '58 chevy's silence...
