Turn off lock/unlock beep?
Discussion in 'Gen 2 Prius Technical Discussion' started by Dummy, Oct 1, 2023.
  1. Dummy
    Dummy Member
    121
    23
    Colorado
    I would like the car to be silent when locking and unlocking. Been googling for an hour and can’t find instructions. Does anyone here know how to do it?
  2. PriusCamper
    PriusCamper Senior Member
    13,470
    5,438
    Pacific Northwest, USA
    I'd like that too... Never run across that as an option. But if someone knows how, this is the most likely place to find that person.
  3. SFO
    SFO Senior Member
    5,302
    4,252
    Northern California
    <striike>You can use Techstream to do it, and there are other obd2 options as well.</strike>
    I misread, my bad.
    #3 SFO, Oct 1, 2023
  4. Dummy
    Dummy Member
    121
    23
    Colorado
    I’m really surprised that it isn’t a simple fix. I turned the backup beeper off a long time ago.
  5. Tombukt2
    Tombukt2 Senior Member
    13,868
    2,520
    Durham NC
    What did you use to turn the backup beeper off?
  6. Dummy
    Dummy Member
    121
    23
    Colorado
  7. Tombukt2
    13,868
    2,520
    Durham NC
    Maybe look in the I don't know how many page manuals posted up here for these vehicles three 400 600 who knows. I do know these things aren't in the owner's manual so but given there's so many computers in the car I would expect there to be all kinds of these fixes if you want to call them that where they were all published I have no idea. I would think by now most of this stuff would have been reverse engineered like the catalytic converter test that's run to set the PO420 code I would have thought we would have learned how to disable that test by now but apparently not so much.
  8. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,017
    NJ-USA
    AFAIK, the only way I know to change the lock beep options is to use an oe level scantool to access the "customize" menu. Tools like Techstream or the ThinkDiag app and device.
    Tombukt2 likes this.
  9. Dummy
    Dummy Member
    121
    23
    Colorado
    I’m surprised. Several other vehicles I have had would chirp the horn when locking/unlocking and you could disable it easily. There’s gotta be a user on this site that knows how to do it. Where are you?
  10. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    There is, and you have already been given the information in several posts in this thread. See post #8.
    Remember this car was designed for the 2004 release and was considered a dealer--customizable option back then. So Techstream (or a pro-level tool) is how you do it. It is quick and easy to do with Techstream.
  11. Dummy
    Dummy Member
    121
    23
    Colorado
    I didn’t catch the part that said they were sure it was the only way.
  12. dolj
    dolj Senior Member
    8,652
    4,403
    If there's another way to do it, no one has found it. Usually, the "chicken dance" manual procedures come from the repair manual and there is understandably no manual procedure there as this is not a mission-critical procedure.
