Turn off maintenance light 2012 PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Conrad, Jul 17, 2013.
  1. Conrad
    Conrad Junior Member
    23
    Santa Clarita, CA
    How does one do that after one changed the oil? This would be really helpful.
  2. markabele
    5,084
    1,782
    Nebraska
    I assume you had it done at the dealer? Have them do it if so.
  3. Dan Cathy
    Dan Cathy Junior Member
    126
    I got this from youtube
    Go to “trip A”
    Power off car
    Hold down “km/h” button and power on car
  4. El Dobro
    El Dobro A Member
    7,102
    3,282
  5. Conrad
    23
    Santa Clarita, CA
    No, I only had the dealer do it while it was free. I change my oil on my 2005 prius(142k miles) every 25K miles. Great car, only work done was rear shocks. Did that myself. Hope 2012 PIP is as good. conrad
  6. Dan Cathy
    126
    PiP should be just as good as a standard Prius because basically it's the same car. Toyota took the Prius and gave it a different type of battery with bigger capacity. It also let you charge the battery by plugging it in.
