Turn off Multi-Information Display "Titles" ?
Discussion in 'Prime Technical Discussion' started by 1x1, Aug 3, 2017.
  1. 1x1
    1x1 Member
    138
    38
    Not sure if this is possibly buried somewhere pretty deep in the menus?
    Each press of the < or > buttons on the steering wheel takes one through the various items of the MID, and then the ^ and V buttons through the sub items. Page 207 of the Manual.
    Each of the items in Drive Information (named Energy Monitor, Hybrid System Indicator, Fuel Consumption Record, etc) shows that name for a few seconds on the screen before disappearing.
    I'm wondering if it's possible to turn those titles off?
    During the learning experience, it's nice to know what these items are displaying. However, once you get to know them, having the titles display for a second or two is not necessary, and blocks what you came to the screen to see.
    Prodigyplace likes this.
  2. 1x1
    1x1 Member
    138
    38
    I'm also wondering if there's a faster way of turning off the bigger (7" in my/Plus case) display? On my old 2007 Prius, I just pressed a button once. On the Prime, I have to press "Home." then "Settings," and then "Turn Screen Off." Kind of a distraction when also trying to drive.
    Also, this main screen doesn't seem to be dimmable?
  3. 2k1Toaster
    5,827
    3,536
    Rocky Mountains
    No you can't disable the titles.
    And why would you turn the screen off? I only have ever used that to turn off the display while the car is parked at night and left READY in sub-freezing temperatures to keep it warm but also make it look more "off".
  4. 1x1
    1x1 Member
    138
    38
    Because it's very bright at night.
  5. 2k1Toaster
    5,827
    3,536
    Rocky Mountains
    Most of my Prius driving is at night, and the screen on dim is no problem. I turn it down so I don't get reflections in the windscreen from the speedometer, and that's perfect. Your headlights should be much brighter than whatever is in the car, and if not that sounds like another problem. This is driving very fast roads with no streetlights, so the only light is the moon and the car. Generally have a cell-phone dash mounted with its screen on too showing GPS and playing tunes.
  6. Lee Jay
    Lee Jay Senior Member
    4,993
    3,622
    Westminster, Colorado
    Turn your dash lights down one notch so it will go into night mode at night.
  7. Tideland Prius
    12,604
    2018 Prius Prime
    Technology
    If it's the same as other Toyotas, there's a brightness/contrast setting for both daytime and nighttime modes (you just have to turn on your headlights in a dark area to access night mode).
    Also, yes, ensure you're one notch from max brightness in the instrument cluster, otherwise the displays will be in DAY MODE.
  8. 1x1
    1x1 Member
    138
    38
    Still wish I could turn it off completely. On my 2007/Gen 2 I could turn off the speedometer and lights on the center console buttons. I think all that remained on was the Ready light.
Loading...
