Turn off the damn backup beep
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by alanvw, Dec 10, 2011.
  1. alanvw
    alanvw New Member
    East Coast
    Hello fellow wagon Prius v owners. Question: is there a way to disable the beep when reverse is selected?
    thanks
  2. cmjars
    cmjars New Member
    Los Angeles
    You have to take it to the dealer and they can change it so it only beeps once when you put your v in reverse. I have read on this forum some people have been charged in my case the dealer did it for free.
    dwfinke likes this.
  3. macguyft
    macguyft Environmental Wacko
    53
    East Lansing, MI
    My salesperson changed it to just one beeb when I picked up our v. One beeb is better than a hundred beebs any day!
    Priusguy78213 and GorgeWindGirl like this.
  4. El_Spectre
    El_Spectre Junior Member
    75
    I asked the dealer, was told that it was 1 hour of labor. They acknowledged that it wasn't much work, but they have a minimum. The customer service manager gave me his card and said to call him before my 5K scheduled maintenance, that we could probably get it done at the time for no extra charge. That's the plan currently.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    A scan gauge II can change it to a single beep. They cost $160ish but they can do a whole lot more.
  6. cmjars
    cmjars New Member
    Los Angeles
    That's sucks... it took my dealer maybe 5 mins and he said he wouldn't charge me anything. I would call my sales person and inform them that they fix it or next time take your business else where.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
  8. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
  9. El_Spectre
    75
  10. Eoin
    Eoin Active Member
    593
    116
    Long Island
    If you have the dealer do it, make sure the mechanic does not have the car door open while doing it.
  11. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    I do it free for my clients upon request. It takes three minutes.
  12. El_Spectre
    75
    I shall answer myself:
    Yes, the "Reverse Beep Query" and "Reverse Beep Disable" codes here: https://docs.google.com/spreadsheet/ccc?key=0AiHL0r_2nhUEdF9lVVBxOVNoN3Zva3E0NmdZTUR1eVE&hl=en#gid=5 work on the v. Now I just get one quick beep, and life is good.
    I at first made the mistake of trying to send a custom command, which did nothing. For other newbies, the trick is to set up the XGauge for the given command, then simply view it. Once you get the "00AC" response back, you're done!
    RichPasco, BaconWithThat and Chazz8 like this.
  13. Cactuscoug
    Cactuscoug CactusCoug
    77
    Redmond, Oregon
    Don't forget to have them set the seat belt warning to one beep as well.
  14. GaryP.
    GaryP. Junior Member
    Tri-Cities, WA
    Re: Turn off the dern backup beep
    After hours of reading and multiple false starts I was able to disable the Reverse beep using my Android phone! Ha!
    Using one of the ELM-327 knockoffs from Amazon.com (2 day free Prime shipping) and 'ELM 327 Terminal' from the android store, it was a 2 minute job (that took me 20 hours to figure out).
    I did all this with the 'Ready' light on and the doors all closed. Not sure if that is needed, but just in case you can't reproduce my results.
    After the terminal program is all connected I just typed the following commands into the little white box on the bottom left of the terminal program (not clear that this is where you are supposed to type and not very big, but it works).
    Turn 'Timer' (right side of screen above 'clear') off (or commands repeat over and over again).
    Commands:
    AT SH 7c0 (hit 'Send')
    Returns: OK
    21ac (hit 'Send')
    Returns: 61 AC 00 (meaning continuous beep)
    3bac40 (hit 'Send')
    Returns: 7F 3B 78 (no idea :)
    Returns: 7BAC (meaning done)
    21ac (hit 'Send')
    Returns: 61 AC 40 (meaning now single beep)
    I then popped the car into 'Reverse' and joy! joy! only 1 beep.
    Kevin W., ToanNgn, DogDaze and 15 others like this.
  15. priusvgator
    priusvgator New Member
    47
    Space Coast, FL
    Thanks Gary! That is awesome!
    Which ELM-327 model did you get?
    DogDaze likes this.
  16. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    I know you guyzzzz like this DIY stuff but if any of my clients are reading this, don't go to this expense or trouble. Just call me and pop in. My service tech can do this free in under 5 minutes. You just need to ask me.
    DogDaze, RichPasco and GaryP. like this.
  17. bisco
    52,853
    another, in a long list of reasons to move to californy.:p
    DogDaze likes this.
  18. vlady
    vlady Junior Member
    42
    Issaquah, WA
    Last Friday stopped by dealer to get plates. It took them 5 min to set to 1 beep for backup and turn of headlights after door closed. No charge.
    DogDaze likes this.
  19. flmedicmom
    flmedicmom New Member
    Our sales person said it was impossible to turn it off, I knwe it wasn't true. Had it in for 5,000 mile service and asked and they said no problem, no charge beep free finally!!
    DogDaze likes this.
  20. GaryP.
    Tri-Cities, WA
    Have not posted enough for the boards to let me post a link, but if you pop B005NLQAHS into the search box on Amazon.com it will bring up the one I bought. I just found one that was 'prime' eligible and did not have too many negative reviews. I did try plugging it into a Taurus today and it did not work, so like many of these knock-offs it does not like Fords.
    Amazon product code: B005NLQAHS : BAFX Brand - ELM 327 Bluetooth OBD2 scan tool - For check engine light and other diagnostics - Android compatible
    RichPasco and priusvgator like this.
