Turn off the damn backup beep
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by alanvw, Dec 10, 2011.
  1. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    great news. thanks.
    jason
  2. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    I had it switched to 1 beep at the dealer. Do it on one if your service trips, since you're in there anyway, it takes almost no time to make the change. My dealer didn't charge, but even if they did charge a nominal amount, it's a lot cheaper the psychiatric therapy from that damn beep.
    DogDaze likes this.
  3. JACoH
    JACoH Enjoying the mileage
    193
    40
    Oregon
    Yes, the "v" wagon is Generation 3
    DogDaze likes this.
  4. alz
    alz Junior Member
    37
    San Francisco
  5. wowMPG
    wowMPG New Member
    2014 Prius Plug-in
    Thanks for sharing. That saved me hours of frustration.
    DogDaze likes this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Anybody know of any decent ELM 327 Windows Phone apps ?
  7. Wildanimalpark
    Wildanimalpark Junior Member
    23
    Greer,SC
    Sitting at Toyota of Greer, South Carolina and I asked for the beep to be changed to one beep and I was told "the district manager made the decision not to change any reverse beeps" Now I must find a dealership that will.
    DogDaze likes this.
  8. blisterpeanuts
    blisterpeanuts Junior Member
    28
    2013 Prius v wagon
    That's annoying. You might try getting one of these Bluetooth OBD units; they're $15-20 on Amazon. Then you can not only silence the back-up beep, but also the seatbelt beep! Join the beeple!
    I hated the seatbelt beep almost as much as I hated the backup beep. Put a heavy piece of equipment on the front seat and it beeps occasionally, then accelerates until it's a constant beep-beep-beep-beep! GIVE ME A EFF-ING BREAK. Turned it off. Sure, I see the red "seatbelt" light and that's a handy thing. But no. more. beep.
    DogDaze likes this.
  9. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    While you guys are at it, disabling seatbelt and reverse beeps, don't forget the annoying horn on the steering wheel! :D
  10. yaksushi
    yaksushi New Member
    Louisville KY
    These steps worked for me! Only issue I had was trying to use my Galaxy Nexus phone to connect to the device. I kept getting errors. I used my android tablet and it worked great. Thanks for the steps.
    DogDaze likes this.
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I know "BEEP" that I'm "BEEP" in the min- "BEEP"- ority here. But I actually "BEEP" like the back "BEEP" up beep.
    I don't "BEEP" get the vast "BEEP" hatred for it?
    DogDaze and Mendel Leisk like this.
  12. Phx_Prius
    Phx_Prius Junior Member
    Phoenix
    This worked perfectly! Thank you!
    I had the Bluetooth adapter, so it was free.
    By the way, for those trying it for the first time, once you're in the app; (since it took me a few minutes to figure it out)
    Don't forget to hit "menu" on your Android and "Connect". Once you're connected, click "Timer off". You're now ready to put in codes, not in the larger white box,
    put your codes in the small bottom left corner.
    I turned off the backup and seat belt beeps.
    What other codes are out there? :cool:
    DogDaze likes this.
  13. Sergiospl
    3,938
    1,351
    28
  14. szmyk
    szmyk New Member
    Poland
    It isn't working with ELM327 v2.1. I get different codes:
    >AT I
    ELM327 v2.1
    >AT SH 7c0
    OK
    >21ac
    61 AC 8F 5B
    (instead of 61 AC 00)
    When I bought v1.5 it works ok.
    DogDaze likes this.
  15. Aaron Roemer
    Aaron Roemer Junior Member
    United States
    2013 Prius v wagon
    I finally got the courage this weekend and hooked up my PC and booted up the Techstream program. I successfully turned off the backup beep. While I was in there I also programmed a new smart key, turned off the passenger seatbelt reminder beep (I set my briefcase there on my way to work), and now all the doors unlock when I grab the door handles. The process was kind of intimidating, but well worth it.
    DogDaze likes this.
  16. JC91006
    16,935
    8,646
    What category in techstream is the settings under for backup beep?
  17. Aaron Roemer
    United States
    2013 Prius v wagon
    Man, I wish I had it in front of me now. I'm not exactly sure, but I think there's a customization tab that you select to get there.
  18. Aaron Roemer
    United States
    2013 Prius v wagon
  19. Aaron Roemer
    United States
    2013 Prius v wagon
    Gen III Prius - Customizable Parameters
    Take a look at this link. This is pretty much everything I found while poking around. (Reminder that this is for the lift back, but pretty much the same.)
  20. mbac
    mbac New Member
    United States
    hi where did you get the Techstream program,I have a 2012 prius
