Turn off the oil change required light -- FOREVER???
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cyberpriusII, Oct 2, 2017.
  1. cyberpriusII
    cyberpriusII Prodigyplace says I'm Super Kris
    1,139
    1,598
    Iowa
    Where is Hobbit when I need him?
    He's the master of all outlaw fixes on the Prius. I remember he removed the snorkel permanently, just because it spit at him....
    Anyway, I've changed the oil in my car some 20 times and that stupid Maint. Req. light is still a PIA to shut off. I never get it right the first two or three tries.
    Hey, any method to turn it off -- permanently????
    I changed my oil two weeks ago and still have not got up the energy to shut off the light -- but if there is a way to do it forever.....???
    SFO likes this.
  2. Prodigyplace
    Prodigyplace Senior Member
    11,696
    11,321
    Central Virginia
    The hard way would be to remove the led from the display. The easy way would be to cover the light with electrical tape. :D :LOL:
    Lucifer likes this.
  3. ChapmanF
    15,890
    It's not just the "hold down these two things while you thing" like in third gen?
    -Chap
  4. cyberpriusII
    1,139
    1,598
    Iowa
    Oh, I don't remember the steps, although I have them written down on the inside back cover of the owner's manual, but my manual is saturated with mouse pee, it is hard to read, the ink is stained yellow and it has run....
    don't get me wrong. It is NOT that difficult, but I never seem to get it right until the third or fourth try. Be easier without the warning light.
    I am capable of knowing when the oil needs to be changed.
    Sort of like those really stupid Tire Pressure Monitoring Systems. I don't trust them, so I still check my tire pressures myself on a regular basis. I don't need an expensive TPMS system.
  5. JC91006
    16,496
    8,404
    1Turn on car, make sure car odometer mileage is showing.
    2 Turn off car.
    3. While pressing the odo/trip button, start the car. You'll see the maintenance meter reset in about 5 seconds[​IMG]
    Raytheeagle likes this.
  6. cyberpriusII
    1,139
    1,598
    Iowa
    You are missing something about having your foot on the brake. Having it on, or not on, at the right time is crucial.
    Again, I do have it written down in ink and mouse pee, but I guess you could call it distracted "maintenance," holding the book, and pressing buttons and stomping on foot pedals, all while trying to balance a can of hops and barley on your lap -- pure misery.
  7. JC91006
    16,496
    8,404
    Steps are the same for gen3, just it has to be on trip A on the odometer.
  8. Mendel Leisk
    38,892
    Canadian Prius don't have that, thank God. Two other cars I change oil on both have a reset requirement, both are a pain. I suspect it's just mandatory, to have to do it 3 or 4 times before it finally takes. :cautious:
  9. Prodigyplace
    11,696
    11,321
    Central Virginia
    Just FYI, on Gen 4, there is a menu item on the MID (Multi Information Display) beside the speedometer to reset the maintenance light.
    Resetting a maintenance light is a poor excuse to upgrade to a Gen 4 though.
  10. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Strange, but I thought I saw it in the Owner's Manual for our '12 v, in the printed section.
    On the '14 iQ:
    Engine running set to TRIP A
    Turn ignition to LOCK
    While holding the MODE button down, turn ignition to ON without starting the engine. Keep holding MODE until trip meter says "000000".
  11. bisco
    49,712
    that's how mine is, last time i tried to reset, it zeroed out my trip meter, which i had been saving.:mad:
  12. Prodigyplace
    11,696
    11,321
    Central Virginia
    You know it is an evil post when @Lucifer likes it. :oops:
  13. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    I didn't notice if it zeroed my A meter or not. I'll try to check...
  14. Mendel Leisk
    38,892
    Note your odometer reading and current trip reading before jumping in, if you care. Odo is where it's at, for bullet proof mileage recording.
  15. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Changed at 13901, current 13996
    Both A and B say 1269.4. Not deleted....
    #15 jzchen, Oct 5, 2017
  16. bisco
    49,712
    it doesn't usually happen, but the procedure is so poorly written and painstaking, i think i had a senior moment.
    Prodigyplace likes this.
