Turn on/off pop-ups - confused?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by ricomtl, Mar 31, 2019.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Page 234 of user guide. I've enabled/disabled these pop-ups settings and I don't see any different behaviors!
    Has anyone experimented with these? Especially with these 2... Multimedia Menu, Instrument Panel Light? I have no clue what they do!
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I have them all turned off and they still pop up. Next to the capacitive buttons around the 11.6" display that activate with accidental touches, that's the biggest annoyance with this otherwise fantastic car.
  3. Tideland Prius
    16,675
    No but I can figure all except multimedia out. (Multimedia might have something to do with changing channels on the radio).
    The instrument panel light pop up is the screen that shows you the brightness level as you’re adjusting the panel lighting using the switches to the left of the steering wheel. If it’s off, then the panel will brighten or darken but you won’t see a brightness scale on the 4.2” MID.
    ricomtl likes this.
  4. Tideland Prius
    16,675
    For climate: when you change temps or open/close the vents or adjust the S-Flow setting, it’ll show up on the MID.
    CC Operation: it toggles the “how to use CC”
    HUD: when you enable the HUD, a pop up screen will allow you to adjust the brightness and height.
    Driving mode select: it’ll show you an animation as you cycle through Eco, normal and Power
    Traction battery cooler: allows the car to ask if it can run the A/C during charging.
    jerrymildred likes this.
  5. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Interesting... thanks. Brightness level... now that makes sense!
    Thanks! :) :)
  6. Tideland Prius
    16,675
    I played around with the radio today and the multimedia pop up didn't come up. I'm not sure what that is now....
