Turn signal/ DRL Lens Crack...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Fleabiscuit, Sep 5, 2016.
  1. Fleabiscuit
    Fleabiscuit Junior Member
    42
    22
    Los Angeles
    Can just the outer lens be replaced without having to purchase the entire assembly?
    I was able to find this part number w/o images.
    Toyota Part No.: 81511-47040
    LENS & BODY, FR TURN
  2. fuzzy1
    10,254
    I haven't actually replaced my cracked unit yet, despite picking up a pair of take-offs last year. (The hole is still covered with clear packing tape.)
    But based on my inspection of the take-off units, and a brief attempt to remove the lens (to allow quicker replacement, without having to replace a missing connector on the take-off) I believe the lens seal is not meant to allow lens removal. When I get around to it, the whole unit will be swapped.
    Fleabiscuit likes this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    easier to do whole assembly
  4. Pinoyrious
    Pinoyrious Junior Member
    16
    24
    Highland
    I replaced mine about 2 weeks ago. I cannot find just the lens, found a new oem assembly on ebay.
  5. Fleabiscuit
    42
    22
    Los Angeles
    Did you find an OEM one or aftermarket?
    Do you have a link?
  6. Pinoyrious
    16
    24
    Highland
  7. xliderider
    xliderider Senior Member
    7,891
    3,125
    Honolulu, HI
    Its 2010 - 2011, then 2012 - 2015 had the refresh.
  8. Fleabiscuit
    42
    22
    Los Angeles
    Update: Since we just purchased this car, being a camera whore, I actually took a picture of the car when it was still on the lot. I took a look at it, zoomed in and saw that the crack was already there. We took it back to the dealer this past weekend and they replaced it with no questions asked.
    Mendel Leisk and Raytheeagle like this.
