Turn Signal Hazard Rear Camera Activation mod
Discussion in 'Gen 3 Prius Accessories and Modifications' started by cproaudio, Jul 22, 2014.
  1. Chris Rogers
    Chris Rogers New Member
    Titusville, NJ
    Does this activate the backup lights? looking at the video it appears that there is quite a bit more light than i would have thought just from the license frame light.
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    No, the backup signal only goes to the nav head unit.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Those are the LED license plate lights you're seeing.
  4. cperera
    cperera Junior Member
    I want to do this to my 2010 Prius with NAV and Backup Camera. Where can I find the installation instructions?
  5. cproaudio
    2,401
    762
    CA
  6. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Will this work on a 2012 Prius C that has an aftermarket rear-view camera installed?
  7. cproaudio
    2,401
    762
    CA
    Is it factory headunit? The TSHRCA does not supply power to the camera. If the aftermarket rear camera get its power from the head unit with factory configuration or powered by ACC then yes. If the camera gets its power from the reverse light then no.
  8. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Yes its a factory head unit that powers the camera. The camera's harness plugs into the headunit and it accommodates the original factory plug. Sounds like it will work.
    Thanks.
  9. cproaudio
    2,401
    762
    CA
  10. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Thank you for the invite, but unfortunately I have other obligations today. Thanks again for the speedy replies and information. I will definitely be purchasing one of your cables in the near future.
  11. Technigogo
    Technigogo Member
    114
    25
    Austin, TX
    cproaudio,
    I want to activate the reverse camera with turn signals and manually when I wish. I also want my passenger to be able to operate all the features of the navigation and audio system while I am driving (Speedlock Override?). So, how do I order for Turn Signal Camera AND the Speedlock Override? I am confused by the SLO option with the Turn Signal thing. Does that include both features? ...and, is the bypass loop simply the on/off switch to undo all these mods for taking your car to the dealer or such?
  12. cproaudio
    2,401
    762
    CA
    You need to order the SLO1+TSHRCA It comes with 2 switches, one for the speedlock override and one for the rear camera. The loop option is a plug that plugs into the override harness between the radio and the module. Since the override harness can be unplugged, it'll make the installation a little easier.
  13. erostrate103
    erostrate103 New Member
    France
    Hello and sorry for my poor english :(
    I'm verry intersted by this system, but we don't have "restriction" on usage of GPS when driving.
    Do you think it 's possible to instal this system on a european prius ? (2010)
  14. eric1234
    eric1234 Active Member
    392
    200
    Hamden, CT
    Will this work in the 2016? Has the wiring been confirmed?
  15. cproaudio
    2,401
    762
    CA
    I have no wiring info for 2016.
  16. james0076ss
    james0076ss Junior Member
    2014 Prius v wagon
    do you have instructions to install this on a Prius v ?
  17. ClintJCL
    ClintJCL Junior Member
    2014 Prius v wagon
    I have a 2012 Prius V. Would I be able to use this in that?
  18. cproaudio
    2,401
    762
    CA
  19. Jason in OZ
    Jason in OZ Active Member
    271
    112
    Sydney, Australia
    Does anyone have a diagram for wiring this up to a 2006 Prius ?
    I'm considering buying one and want to know how and where to hook it up.
    Australian spec cars don't have a front power socket in the dash, so I know I'll need power from somewhere else, but want to know what else I'm going to have to do.
    Jason.
  20. MP_Geez
    MP_Geez New Member
    17
    23
    Hello, I have a 2013 and i just installed an aftermarket backup camera. This one (
    I do not have Navigation. I am interested in being able to have the rear camera activate by turn-signal, hazard, and manually turn it on while driving without using the signals / hazards. Will i be able to use your device for this? Which option should i select to purchase? The backup camera i got has a harness that plugs into the back of the radio and the existing radio plug connects to it. I just want to make sure that i'd be able to use your device with this current setup.
