Turnigy Reaktor Charger Info
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dirt657, Jan 24, 2019.
  1. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Hey guys. Been messing around with these IMax B6 knock offs for a while. Done about 3 batteries for my personal priuses as well as some I've flipped. Didn't take me long to realize that these chargers are really not great at all. I bought 5 Reaktors with power supplies. I just want to know how accurate these guys are...With these IMax B6's I had to set discharge down to 5.7V because they are EXTREMELY off. 5.7V discharge brings the battery down to just over 6v, verified with a voltmeter of course. On top of that, when I set the limit to 7500Mah on the charge cutoff as well as the "D.Peak" option to 20mv, the chargers do not want to shut off and I really run the risk of over charging if I'm not careful. Thus the reason why I jumped ship to the higher quality Reaktor....So now come my two questions since I can't seem to find any clear answers.
    1. I hear they don't come with the right cords needed to charge the modules. What cords will I need to get? I can't find a good open box picture.
    2. Which settings are you guys running for these chargers? It's a pretty good profit in my area and I may end up spending a grip and getting another 23 of these if I can get a good system going. I can't trust leaving the B6's alone. I'm told I can trust these a lot more.
    Thanks for your help. I've consciously looked around and can't seem to find the right answers.
  2. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    There are good photos of the unit on Amazon. I think most people make their own cables to connect to those banana plugs on the side.
  3. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Yeah I got mine in today. I made it work. I just need to know the settings everyone is using.
  4. Skibob
    2,912
    1,496
    Northern California
  5. lunacyworks
    lunacyworks Member
    114
    SF Bay Area
    Thanks for the link, but reading 2600 posts that are largely outdated are not a help. Help would point to the lastest relevant post. I would be nice if the main post was updated with the most current info. Is there a way for us to do this? I am all for reading and understanding completely, then there is the issue of learning the wrong ways or outdated ways which is not only dangerous but a waste of time.
    Ok I just did a quick summary of the first 400 post. I will update as I continue re-reading the post.
    Post #2
    settings
    5 amp Charge
    .7 amp Discharge to 6V
    6750 mAhr
    dsch<chg 3 cycles
    Post #4
    Same capacity - within about 0.2 ah
    Same terminal voltage - within 0.05 v by controlled discharge of high modules
    Same series resistance - within about 10% (you can pair up modules to control this further as the resistances add)
    post #63
    Here's what I was looking to use for settings:
    2 amp Charge
    1.0 amp Discharge to 8V (1.0V per cell, 8 cells per 9.6v battery)
    7250 mAhr (I assumed battery capacity was the same, just different voltage)
    dsch<chg 3 cycles
    What voltage would you enter for charging on the X4? (nominal 9.6V? other?)
    Post #65
    The modules are counted from the terminal (high voltage ECU) end of the battery. The module nearest the ECU being (1) the furthest away being (28).
    Post #67
    The upper battery carrier torque: 5.5 N*m 49 in*lb
    The upper battery cover 8 N*m 71 in*lb
    Battery Assembly 19 N*m 168 in*lb
    Frame wires 5.6 N*m 50 in*lb
    No. 6 Battery carrier panel 7.5 N*m 66 in*lb
    Remaining brackets 28 N*m 248 in*lb
    Post #72 Sample workbook.xlsx
    Post #92
    Some info on data to collect
    Post #117
    [Recommended 10 amp max charging]
    Actual charging time should be 39 minutes at 10 amps (39mins divided by 60 minutes x 10 amps = 6.5 AH). The charging time would be slightly longer than this because of losses say 10%.
    Post #130
    Link to youtube video on capacity test
    Hybrid Battery Capacity Test | PriusChat
    NiMH Battery Specifications - HYBRIDS
    Post #156
    Describes how a pro system was setup and used, gives good reference numbers.
    Post #177
    Link to setting for using a Hitec X4
    Prius Battery rebalance thread | PriusChat
    Post #197
    list of common mistakes (shorting, using torque app), over torquing bolts.
    Post #205
    Claims 2amp charge rate is too high [my note: only true if not using Delta V)
    Post #207
    Clarifies says 5 amp is too much, need to taper at end.
    Post #245
    Summary of tips from a user for their Highlander battery check
    Found 2A charge rate worked well for him
    Post #265
    Sample setting for Hitec Charger setup. (warning disables delta v)
    Post #306
    Yes, it is essential to do parallel equalization prior to reassembly and installation. (now questionable advise?)
    Post #322
    advise on Parallel equilization
    Post #340
    Link to goverment test
    http://www1.eere.energy.gov/vehiclesandfuels/avta/pdfs/hev/batteryprius1052.pdf
    Post #345
    If you have all cells out, turn them all the same way and loop wire for quick Equalization.
    #5 lunacyworks, Sep 10, 2019
    tri4all likes this.
  6. Skibob
    2,912
    1,496
    Northern California
    Well there is a search feature here if you don’t want to read that post. Best of luck.
