Turning Off Tire Pressure Sensor
Discussion in 'Gen 2 Prius Main Forum' started by vinnysca, Sep 5, 2006.
  1. vinnysca
    vinnysca New Member
    200
    Has anyone figured out a way to disable the tire pressure warning light off? Is there a fuse of some sort? I am dying to find a way to turn this light off, especially once I decide to buy a set of 17 inch Scion TC wheels. :D
    Or, has anyone upgraded to larger wheels and had Toyota put on and calibrate new tire sensors? If so, was it worth it?
    Thanks.
    Vince.
  2. rayMOO
    rayMOO Junior Member
    Leavenworth, Washington
    no response huh? same here. I have the same problem
  3. rayMOO
  4. fuzzy1
    10,335
    Numerous drivers have applied a little patch of black tape over the light.
    afpri likes this.
  5. bigblockcutlass
    bigblockcutlass Junior Member
    23
    Don't know if you can disable the system. I bet not. Pull the bulb if you can do that even. Or buy Dorman part number 974-033 time's 4 and install them, then you have to have them programed with a scan tool. Don't forget to wright the code number off each sensor before you put the tire on the rim. You will need that number for the scan tool.
    Just went throught this with a set of Fireston snow tire's I just bought. I would just like to know how to program two set's of tire's to the car like my scan tool says that can be done with this car. Feeling the scanner wrong on this one.
  6. PriusGuy32
    1,417
    513
    Harrison Township, Michigan
    What baffles me is you CAN disable the TPMS on the Gen 3 and on just about every other late model Toyota vehicle (Yaris, Camry, Tacoma, etc) but there is no mod for a Gen 2?! Somebody with electrical wiring diagram experience has to pin out their Gen 2 TPMS and figure out with wires to jumper to provide the necessary signal to the module to trick it like they did in the Gen 3 TPMS disable mod.
  7. Zarranova
    Zarranova New Member
    Woodstock
    I have a Gen 3 and would like to disable the TPMS light. In my state it won't pass inspection if the light is on. Do you know how to disable it?
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    There's no trick out. You use Toyota techstream software and remove it in the software.
  9. Paranormal Rob
    Paranormal Rob Active Member
    244
    107
    RDU NC
    2013 Prius v wagon
  10. Paranormal Rob
    244
    107
    RDU NC
    2013 Prius v wagon
  11. PosauneGuy
    PosauneGuy Member
    120
    California, here I come...
    2025 Prius
  12. Mendel Leisk
    40,582
    If it's not to bypass an annual inspection, I would just ignore the light.
  13. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    I have 18 inch rims on my Gen 2 and I drove without TPMS for 8 months because when I put the new tread on my tires I did not choose to swap the TPMS from my original rims period but when I bought new tires I had them put the Toyota TPMS in my 18 inch rims. It's very good to have on especially when you can't really tell if a 35 series tire is flat or not
