Turtle uphill and Hybrid system overheat... please help
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Shahzad Nayyar, Sep 19, 2019.
  1. Greenteapri
    Greenteapri Active Member
    330
    387
    Cypress
    It's dusty, for sure. How's she running now?
  2. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    25
    Pakistan
    Well like i said. It runs smooth. Did the same earlier. The test will be on mountains where the car needs every bit of power. Will check and let u people know
  3. Shahzad Nayyar
    94
    25
    Pakistan
    I think the previous japanese owner did... there were quite a number of hair removed from the fan
  4. Shahzad Nayyar
    94
    25
    Pakistan
    Has anybody here ever used engine oil to grease up the motor/ bushes? My mech wanted to do that but i did not agree as it is very close to the HV battery. Your comments please
  5. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    The battery should not really get so warm when going uphill.
    More when breaking / accelerating like on a road with many roundabouts
    But you should always keep the fan clean.
    And lubed. I don't see how oil could interfere with the battery
  6. mjoo
    mjoo Senior Member
    1,161
    1,329
    Michigan
    Motor oil has metal additives in it that are conductive. IMHO it would short the brushes and cause a fire. If lubing the fan, I'd first clean out the old lube and replace it with new Toyota dielectric lube.
    If he wants to do more, instead I'd have him install a filter on the battery air intake. There's a Toyota part number floating around here somewhere on PC.
    #46 mjoo, Sep 27, 2019
  7. Ali Rashed
    Ali Rashed New Member
    Islamabad
    Hi Shahzad,
    I am experiencing the same issue with my 2014 Prius. can you please help share what you did exactly to fix it?
    My cell number is as follows:-
    please share yours so we can chat it out on the phone. Thanks,
    +92-340-4508340
    +92-321-3313393
  8. Shahzad Nayyar
    94
    25
    Pakistan
    Aoa and hello!!!
    Turned out there was air in the cooling system. I removed the temperature sensor and pressed the different pipes on different occasions. At one time i removed the sensor and turned on the engine. Be ready for coolant spill
