Two Coolant chambers?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ridz, Aug 9, 2017.
  1. ridz
    ridz Junior Member
    Okay, this might sound dumb to most people here, but I really need this answer (tried searching, no clear answer found).
    Prius has two coolant chambers. My question is, do I use the same coolant for both? I didn't find the owner's manual suggest different coolant for each, it just mentions what type of coolant I should use. So I can use the same coolant for both, right?
  2. ridz
    ridz Junior Member
    2014 Prius Three
  3. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    Yes, the same coolant in both the inverter and engine coolant loops.
    ridz and Raytheeagle like this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,756
    1,784
    Bay Area
    Yes, they're both 50/50 super long life coolant.
    ridz likes this.
  5. ChapmanF
    18,955
    ... which, to be clear, is already 50/50 in the jug when you buy it. No mixing on your part.
    -Chap
    ridz and NutzAboutBolts like this.
