two different key fobs in one prius
Discussion in 'Gen 3 Prius Technical Discussion' started by priusguy469, Oct 23, 2011.
  1. skilbovia
    skilbovia Member
    400
    91
    Massachusetts
    We also have two 2010 Prii. I often drive with both fobs in my pocket and haven't seen the problem. I have another friend with a 2010 and there are no problems when I ride with him or vice versa.
    Thanks for the tip on the RFID chip. I had no idea.
  2. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    I had the same problem with my Gen. II. When you have two or more fobs, sometimes they fight. Or sometimes they will synch up and flash their tiny red LEDs in unison. Stick one in a metal container with a tight fitting lid and it will shut up and stop bothering the car. An Altoids/Sucrets/cookie tin is fine.
  3. WolfpackBill
    WolfpackBill Senior Member
    349
    501
    Lexington, NC
    My family has 2 2010 Prius IV. In fact, the only difference between the two of our cars is the exterior color. Mine is Classic Silver and my parents' is Winter Gray. I did this experiment the other day and have found absolutely no problems getting the doors unlocked and start either cars.
  4. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    My friend's 2010 has this issue as well..when my key is on my person from my '12
