Two thousand eleven prius, I think the fuel pump maybe going need some advice
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bobby515, Jun 23, 2025.
  1. bobby515
    bobby515 Member
    181
    phila
    Starting a new thread to get proper help. I can do a lot of my own work.
    I am stumped now.
    My 232k pruis ran great every morning and sometimes all day. When it seems to sit after I do uber in am break..We had heatwave here.it acts up. not always this is new problem.
    After it sit's no engine codes. The car lacks power. No really bad misfire
    . Hard to get it to 60 mpg..just now in am its running good 5am. 2 days ago i did like 40 city rides in 100+ degree heat. No problem's.
    I was thinking a cat was bad.
    Why, for 2 years on heavy highway acc. i would smell rotten eggsThe .
    Cat was testing at a small shop yesterday, and they said it's good. Exhaust shop only.
    My battery on Dr. Pruis is 52%.
    I did a head gasket in September.
    Starting fresh, I am very handy, and steps to take to test this car.
    I am thinking fuel pump..
    .but I would like if you kind members and point me in the proper direction...only starting happening on Mondays, hot heat at my 10am break of 2 hours to go back to work. Tuesdays, it was fine.
    Thursday's am ran great, 3 hours. After it sat. Ran like crap. But not a big misfire. I'm back to normal.
    Please point it in in a step-by-step testing... It's a good car, thank you guys.
    Bob is confused in Philly, but very patient. I really love my Pruis.. all except the driver seat on long days..age (62) on the 4th
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,162
    6,316
    Texas Hill Country
    Does the car burn oil?
    Sounds like a bad cat. How did the small exhaust shop "test" it?
    Prius Gen3 Aftermarket Cat $450
    Walker 16649 Rock Auto or Amazon
    Amazon.com: Walker Ultra EPA 16649 Direct Fit Catalytic Converter 2.375" Outlet (ID) for Toyota Prius : Automotive
    They say love is blind...
    #22 rjparker, Jun 27, 2025
    bobby515 likes this.
  3. ASRDogman
    ASRDogman Senior Member
    7,602
    3,915
    :(:confused::eek:o_O(n)
    Starting a "new" thread for the same issue will only create issues because people will see
    double posts and won't know where to post or where to look...
    Brian1954 likes this.
  4. bobby515
    bobby515 Member
    181
    phila
    If we're gonna install an aftermarket cat,
    I bought pretty cheap on eBay, but they said they don't think it's clogged
    . They took the 02 center out and ran it while the car was running bad. Without the 02 sensor and the car still ran the same bad.
    Now this morning, the car's running good. So I really don't know my buddy, who works for Cadillac. its kind of a pain i* t** a**. Sometimes, a friend of 45 years told me to do a pressure test on the converter.
    The guy at the small shop said that the cat was ok. It would put debris in the resonator. Behind it, where you have the heater lines in the resignator,
    I was going to do the bypass on that anyway.
    Have I seen from gasket masters? So now I'm kinda stuck. They were only going to charge me $100 to put my new converter on, but they said that behind my converter, the resonator might be full of debris. So they decided to pull the 02 sensor out and said that the car should have more pickup,
    because air will bypass the cat. What's your thought worst comes to worst ? I can go back and have them. Put the cat on at a $100 labor cost, you have to. Weld it to the resignator caught it with a reciprocating saw.
    But before they pulled the sensor, they got me thinking that the debris, if there is, could go inside the resonator, which would make it still clogged. So I'm kind of confused about that. The good thing is, if it is the converter only, it's not a lot of money. Because the converter was cheap.
    I have no lights on the dashboard. The reason why I suspect the converter. When the car gets hot in the city, driving it for say, Uber, I do my x. Amount of ride, say in the morning when I bring it home. And I leave it sit, it seems to act up. I'm talking like three times. I started it up this morning. It's starting to run a little funny in the morning for just a couple of minutes.
    No rattle, sounds like a misfire, and then it has the fast power in the morning. You jump right on the highway. You go anywhere you want, and when it acts up, it seems like it acts up after it's been shut off for a little bit. Yesterday afternoon, from like 3 PM. When I went to the shop, when I came back, it was steady bad. What's like, uh,
    I don't want to say a misfire, cause it wasn't like a bad plug, and you could smell a little bit of sulfur, a little bit. Sometimes any advice would help, I mean, I could always say, just put the converter in, what happens if the resonator is blocked?
    The reason why I was going change converter myself. is of course it needs to be welded.
    And these little Pruis in the driveway tend not to be stable on Jack stands.
    I have a professional forklift, jack, and jack stands, but it's senseless for the low price of ninety-one hundred dollars installed. For me to climb under, what are your thoughts?
    I appreciate your responding to me. I'm just baffled by this. And I have a lot of general car knowledge. I was a car customizer as a living years ago, and mechanically, I'm pretty sharp. I put my own time in the chain and head gasket on. I put the wheel bearing on I put struts in. Ball joint tie rods.
    i edited this to be cleaner..sorry about the bad grammer
    #24 bobby515, Jun 27, 2025
  5. bobby515
    bobby515 Member
    181
    phila
    Sir, could you please? Delete the first one, because I think this one is more important 2. Let me do it.Step by step has per guessing.Like I did the converter. I'm guessing fuel pump and so on. I hope with the forum board. Somebody could walk me through to try to figure out the problem. But I drove the car in 4 days, 3 and a 1/2 days for business. My job is UberX driver. I'm 63 years old next Friday. The 4th of July. I appreciate any help and I'm sorry. I posted 2 topics. What I realized was I jumped a gun and taking shortcuts, and the reason why I did that was because I thought I knew my car.
  6. bobby515
    bobby515 Member
    181
    phila
    No oil burning a half a half a quart every five thousand miles
    What basic symptoms does a fuel pump have? On a prius, would it go bad in the heat or all of time?or a clogged. fuel pump filter in the tank
    #26 bobby515, Jun 27, 2025
  7. bobby515
    bobby515 Member
    181
    phila
    Could you tell me how to find my first post? So I could delete it next time. That's my biggest problem finding my posts. I could easily delete it. And not confuse the board, thank you.
  8. Mendel Leisk
    41,486
    About the 7th similar thread.
  9. Brian1954
    Brian1954 Senior Member
    2,221
    874
    South Central PA, USA
    You can not delete a complete thread. Only a moderator can do that.
    I have reported this thread to a moderator and asked him to merge this thread with the other thread that you created three days ago, https://priuschat.com/index.php?posts/3544744
    If he decides to merge the threads, It may take up to 24 hours to happen.
  10. bobby515
    bobby515 Member
    181
    phila
    could you post a link to that pump??
  11. bobby515
    bobby515 Member
    181
    phila
    thank you. i am online trying to clean up my old mess. sorry...
  12. Tombukt2
    Tombukt2 Senior Member
    13,008
    2,330
    Durham NC
    2010 Toyota Prius Fuel Pump with Sending Unit A-Premium APFP0380 | A-Premium https://share.google/VNwYqKhcyZX9i5W0d. So take a look at the fuel pump is not the plastic trim around it it comes off the pump is the gold or silver metal and black plastic end that accepts sock filter . You can buy this body type pump fits in Toyotas from 85 to well gen4 probably .the plastic pieces clip back around new pump body .you'll see when you're comes out . The same Toyota fuel pump also goes in my Italian motorcycle the exact same Toyoda pump from same supplier . I put them all in .and they work 1 is about ten years old now in a 02 Corolla .still fires rt up about three times a year no one will drive it
  13. bobby515
    bobby515 Member
    181
    phila
    So you buy this take apart the old pump. Install the pump only. Not a complete assembly correct??
  14. Tombukt2
    13,008
    2,330
    Durham NC
    The complete assembly with all the plastics can be had for about another $34. I don't buy all that I just pull pump assy like I'm pulling it out of a well . Pull plastics off remove spade connectors etc . Put the plastics around my new pump and reinstall. 25 min job once seat bottoms on floor . Hopefully almost out of gas . Is highly flammable . Lots air needed . Once pump is out drop a rag over hole in tank . And get away from vehicle to disassemble reassemble pump . No sparking metal tooling going on drop plastic assy in tank quickly apply hoses to cover plate and get in on on short order . Screws in by hand . Then let area air out .
  15. bobby515
    bobby515 Member
    181
    phila
    i will probably buy complete as i have a small garage but row home style. what about the old gasket..o- ring..do you replace that. i dont want to just replace parts but for $100 this makes smart sense. probably org pump .tks
  16. bobby515
    bobby515 Member
    181
    phila
    i see same brand on amazon for $100 . i can get tommorow, and put in sunday
  17. Mendel Leisk
    41,486
    Click on your avatar, then "Postings":
    Down at the bottom of the posting page, click on "Find all threads...":
    upload_2025-6-27_9-5-12.png :
    bobby515 and Tideland Prius like this.
  18. BiomedO1
    BiomedO1 Senior Member
    3,651
    1,882
    SacTown, Ca
    Have you checked or monitored your engine operating temperature? Overheats over 245F will trigger your dummy lamp, anything below that won't register and doesn't get caught up in your CEL. If your electronic water pump is intermittent, it may not throw a code - but watching your engine temperature will tell you what's going on.
    Good Luck....
  19. Tideland Prius
    16,559
    *Merged threads* I made a note on the first post as well.
  20. bobby515
    bobby515 Member
    181
    phila
    I did the regular dr pruis test it came out to 52% fair. I got a warranty till July 31st.
    What other tests is good to post.?? From Dr pruis.
