Two vents for Hybrid battery?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Coast Cruiser, Sep 16, 2016.
  1. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    You will probably need to force the vent fan on for the tissue test.
    Coast Cruiser likes this.
  2. Tideland Prius
    16,678
    So it's an "obscure fact"?? Middle vent = NiMH, side vent = Li-Ion?
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Mine has both - in the first photo, you can see part of the side one.
    Tideland Prius likes this.
  4. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    Has anyone opened up the hybrid vent cover? I saw there's one screw holding it. How many mice am I going to find in there???:LOL::eek:
    Wraiththe, RCO and alanclarkeau like this.
  5. bisco
    52,831
    three blind ones, no doubt.
    RCO, Coast Cruiser and Mendel Leisk like this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think TP meant just the long thin vent, we all have both.
    I think it's a smelly feet extractor :whistle:
  7. apt49
    apt49 Junior Member
    63
    Seems that ZVW50 prii (NiMH traction battery) have one vent in the centre, while ZVW51 (Li-on traction battery) have both or the larger one.
    Maybe it is for better Li-on traction battery cooling, or controlling air flow on special occasions? If I recall ZVW51 have a hydrogen gas exhaust connected to the Li-on traction battery to comply with future regulations about safety against possible explosion and fire cases might have been happening on cars with Li-on traction batteries. Could have been possible to be part of a system related to such future regulations?
  8. MrMischief
    MrMischief Active Member
    426
    443
    Denver CO
    I believe a lithium battery only produces gasses when exposed to water. The battery then releases multiple gasses including hydrogen, carbon dioxide and carbon monoxide. Not something I'd imagine they want venting into the car. Eventually the battery catches fire in dramatic fashion. So if there is an exhaust vent for gasses from the battery I would bet (and hope) it's vented to atmosphere rather than the cabin of the car. Nickel batteries will release hydrogen if overcharged, something that occurs more often than water on a lithium, which is why they are typically vented to atmosphere.
    My guess is still that the vent has to do with cooling the battery since lithium batteries are much more temperature sensitive. I don't know anything about the prius battery but my small understanding of lithium batteries comes from a few years ago when I used to play with RC cars. My understanding is that if the battery has a cobalt cathode, at 302* F they can become unstable and will begin thermal runaway resulting in a big fire. Manganese cathodes can go up to 482* F. You can mix the two materials (and others) to balance performance and temperature which is probably what we have. The possibility of thermal runway in my backseat is never far from my mind, but it's just been something I'm aware of, other than placing items behind the driver rather than the passenger (my theory is it's a blow vent not a suck, plastic bags on the floor won't block it) I don't do anything different than a normal car. I still continue to haul buckets of salt water in my trunk on a weekly basis (although I do find myself triple checking the lids) and I don't crack my windows on a regular basis. But if I ever thought I noticed something like a smell or extreme heat coming from the backseat I would run far away from this car. I wouldn't say I'm scared of this car in anyway, I'm just aware of the risk.
    RCO likes this.
  9. Griogarach
    Griogarach New Member
    27
    16
    Germany
    Is it to relieve cabin pressure if you slam the back hatch or a door closed quickly?
    Your move quite a volume of air when you close that hatch I'll bet. Most modern cars are very well sealed around the cabin for noise reduction. Moving air needs somewhere to go or the doors would close with resistance.
    The cabin heating up during the day would also increase in pressure slightly.
    Many vehicles release the air from the cabin through a similar system, often out through a trim-piece into the space between the panels.
    Less often some older vehicles would vent behind the wheel arch liners.
    They all had a flap or reed valve that would keep it closed until needed.
    If I remember, I will have a look at mine next time I'm giving it a clean out.
  10. alanclarkeau
    7,045
    7,593
    This is Li-ION layout
    NiNH Battery
    Wraiththe, KMO, DevilDogDoc and 3 others like this.
  11. Wraiththe
    Wraiththe Member
    279
    53
    Charlotte NC
    I am pretty sure it is for exhaust from the battery fan. If you look at this video, link is at the right spot, you can see the cooling duct ends there.
  12. Robert21PrimeLTD
    107
    50
    South of Nashville
    2021 Prime Ltd have 4 air vents for the high voltage battery. 2 at top and 2 at bottom of rear seats.
    vvillovv likes this.
