Type "A" Fuse?
Discussion in 'Gen 2 Prius Audio and Electronics' started by kenkneeb, Nov 2, 2005.
  1. Seaside Harry
    Seaside Harry Junior Member
    83
    Chesapeake, VA
    2014 Prius v wagon
    Since Ken did the hard work identifying this fuse, finding sources should be a piece of cake...or so you'd think. This product appears to be new enough that neither Bussman or anyone else appears to be making 897-series equivalents yet. This was the only online auto parts place I found that carries them:
    http://autobodysupplies.safeshopper.com/30/502.htm?505
    You know something is really scarce when eBay doesn't even have it. Right now, the best prices seem to be at the electronics parts houses:
    Mouser Electronics, average price $.38 ea, $3.30 for 10
    http://www.mouser.com/index.cfm?handler=da...odenumber=57608
    No doubt, the UPS charges would overcome any savings unless you buy a zillion fuses or need other electronics stuff anyway. As much as I hate driving anywhere to buy anything, I guess the best bet for now is to try the local Pep Boys as KenyOregon suggests.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    Depending on shipping costs, the fuse assortment at autobody supplies looks like a decent deal.
    How about a group buy from Mouser? Someone could order 100 assorted pieces and produce an 'emergency' assortment. Could easily be mailed to individuals probably for less than a buck.
    What is the difference between 0897015.N and 897015.N?
    Besides the leading 0 for you wise guys/gals out there.
  3. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Mouser will ship in through any of the big three carriers. I got a shipping estimate from them to me in Arizona for USPS at less than $6 for one pound and less than $7 for two pounds. I couldn't find the weight of these fuses, but I would imagine you could get an awefull lot in one or two pounds. At two lbs and $7 shipping (worst case est.) 100 fuses grouped by several different amps would be just under $40, putting it at about 40 cents per fuse. Even at 10 fuses, it works out to a bit over a dollar per fuse, still beating Toyota's parts department
    Dan
    The leading zero seems to indicate a different product group. The 10A fuse is brown with the zero and red without it. Also, the fuses with zeros have RoHS COMPLIANT in their blurb, which appears to mean they are lead-free. It probably dosn't matter which ones we use, as long as we pay attention to the amp rating instead of relying on color only. Although, sence the Prius is such a green car, we should probably favor the lead-free. B)
  4. c4
    c4 Active Member
    607
    51
    Yes, but how many fuses do you expect to blow?? In all my years of car ownership, I've replaced a total 5 fuses- two of these were on friend's cars and one was in a big International tractor, leaving two in my own vehicles, and one of those was because of bonehead move under the dash while testing a stereo install (slipped with a test probe and shorted the power to ground).. A hundred fuses would be more than you'd ever need for yourself, your immediate friends and family and probably your whole neighborhood..
    Certainly, on a unit-cost basis, it's cheaper, but if you only use 2 or 3 out of 100, you still come out ahead in terms of cash remaining in your pocket by going to the dealer..
  5. DanMan32
    3,799
    27
    Tampa Bay, FL
    Be careful Hawk, I thought they were different colors too, until I realized I was not looking at a matched set. They aren't in any reasonable order.
    C4: What we are figuring out is that one of us could do the mass purchase, and mail out an assortment to those who would want them.
    Considering cost of fuses, cost of mailer, and postage.
    Probably could be done at $5 for an assortment of 1 each.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    In Japan, I paid 60 yen (about 50 cents) each at a Toyota dealer.
    Please make sure how much your local dealer wants.
    Ken@Japan
  7. geologyrox
    geologyrox New Member
    513
    my husband buys from mouser on a regular basis. i'll have him order a gob of them - but since i don't have my prius yet, i need to get you guys to tell me what i need to order.
    mouser appears to carry the 2A (Grey), 3A (Violet), 4A (Pink), 5A (Tan), 7.5A (Brown), 10A (Brown), 15A (Blue), 20A (Yellow), 25A (Natural), and the 30A (Green).
    They are 'on order' for the 3, 4, 7.5, and 10 amp versions.
    They all run roughly the same price - about 35 cents each.
    What would make a good replacement variety pack? Is one of each reasonable, or should there be two of the 15s, or something? I don't mind doing this, it's sort of what i do for a living anyways =)
  8. DanMan32
    3,799
    27
    Tampa Bay, FL
    Well, doing a crude search in the owner's manual, I see 9 7.5A fuses, 14 10A fuses, 13 15A fuses, 3 20A, 3 25A, and 7 30A. This does not account for reallocation of fuses in certain slots, such as HID or Halogen, which use different fuse values, and includes the spare fuses. I am using these numbers as is for approximation.
    I'd say put in 2 each of the 7.5A, 10A, and 15A fuses, 1 each for 20A, 25A and 30A. That's nine total in an assortment. I'd say $5 for a 9 piece assortment should do it.
    Then again, that leaves only $1.80 for packaging, shipping and handling.
  9. hawkjm73
    hawkjm73 New Member
    258
    Phoenix, Arizona
    Don't quite understand that. Willing to be a bit more verbose? If it helps any, I was only compairing that one pair of fuses. I hadn't gone through the whole group.
  10. NuShrike
    NuShrike Active Member
    1,378
    This word is only used when you know you will never see this person again. It's equivalent to farewell forever.
  11. gyurk
    gyurk New Member
    Mouser Electronics has no minimum order and charges actual shipping cost. I've ordered from them many times with no problem.
    http://www.mouser.com/?handler=data.listca...=SField&N=57608
    Look for manufacturer's part numbers starting with 0897.
    Paul
    PS: Oops. I see others have already discovered Mouser. I didn't notice this until after I posted.
  12. DanMan32
    3,799
    27
    Tampa Bay, FL
    I didn't see both pairs of 10A fuse, until I searched for the mouser part number without the leading 0 and got both. I believe the spec indicating a brown color is a misprint. Looking at other fuses, it seems to be a standard that 10A fuses are red, and 7.5A fuses are brown.
    If you search mouser for Littlefuse brown, you'll see that the 10A is an oddball and the rest are 7.5A.
  13. Ghostrider
    Ghostrider New Member
    121
  14. Ghostrider
    121
    <div class='quotetop'>QUOTE(Ghostrider @ Nov 12 2006, 09:44 AM) [snapback]347808[/snapback]</div>
    Well I found a sampler set at O'Reilly's.
  15. prberg
    prberg Member
    155
    Burbank, California
    <div class='quotetop'>QUOTE(Ghostrider @ Nov 12 2006, 10:44 AM) [snapback]347808[/snapback]</div>
    Sorry... that would be a great set, if they were the correct fuse. The blades on those fuses from Harbor Freight are too long. As someone else said they might work but will stick out farther than the correct fuse. Let us know if you find anything similar in the correct size.
    thanks,
    -Peter B
  16. davidb
    davidb New Member
    I just ordered 3 of each "mini-fuse" value from 2A to 30A (27 fuses total) for $0.58 each from Mouser Electronics. With shipping, the total came to around $20.00.
