Typeface for In-car Display?
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, Aug 27, 2019.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    Hello, I was wondering what font the car uses in the gauge cluster and screen... For some reason I like it alot? Anyways thank you and sorry if this is a dumb question.
  2. EyePrime
    268
    115
    2018 Prius Prime
    Update: The font "monda" on google docs looks quite similar. But I dont know if it is for sure.
    Please comment if you have more info about the font
  3. Jamesb93612
    Jamesb93612 Member
    133
    69
    Clovis, Ca
    You can take a picture and upload it to WhatTheFont! « MyFonts
    I used to use it when I was doing graphic design. It should give you an idea of the font. Hope that helps.
  4. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    Cool tip! Thanks.
    If any of you find out the answer, I too would be curious (I don’t have a photo handy).
  5. Elektroingenieur
    2,515
    3,288
    Three Touring
    In the software for the navigation receiver assembly with 7-inch display, the fonts are delivered in OpenType format and identified internally as “Tfont1212c,” in ten combinations of weight and width. The files include a Toyota Motor Corporation copyright notice dated 2012, with no mention of a type foundry or outside supplier.
    I imagine it’s a typeface developed or customized for Toyota, but I’m not sure it’s an original. In my experience, neither WhatTheFont!, kindly mentioned by @Jamesb93612 above, nor Identifont has been completely reliable, even for typefaces that have been in specimen books for years.
    It’s definitely not Monda; compare Q, J, 1, and 4, for example.
  6. Salamander_King
    Salamander_King Senior Member
    11,024
    8,977
    New England
    Can you upload photo of the screen? I am just curious as to which font you are talking about and what it looks like. Is this on the MID on dash or on 7 inch display?
  7. Tideland Prius
    16,659
    @EyePrime updated the title to be more informative.
