Typical lifetime of 12V battery...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ichiro, Mar 28, 2012.
  1. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    How many years?
    Sorry, I guess 5years. Just noticed your avatar.
  2. jpmyers
    jpmyers New Member
    New Smyrna Beach, FL
    Just replaced mine after 5.5 years and 222,000 miles. Vehicle has been used in FL.
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Were you having problems?
  4. jpmyers
    jpmyers New Member
    No, it was at the dealer for another issue. They called to tell me that it died while they were servicing it. They asked me if I was having recent problems starting the vehicle. Told them not at all or ever. Since it was so old, I just said replace it. I had no choice!
  5. mikesarebetter
    mikesarebetter Junior Member
    53
    south dakota
    I'm looking at buying one of the Exide batteries, surprisingly from a localish dealer. The total price would be about 196 which is slightly cheaper then both the oem and optima in my area. I could get the Exide for about 30 dollars less if ordered online but for warranty purposes prefer to have a local store i can return the battery to.
    My 08 still has the stock battery, and so far this winter have seen temperatures as low as -5, it started right up. I did connect my torque reader before start up, and in ACC mode my volts were only reading 10.4v at this -5f temp, i did not turn on headlights for a load. Checked the volts today when the temp is 45f before start up and it was at 11.9v and 11v with lights on.
    My main question is how long can a battery stay good for if not used? I know batteries sitting idle is bad, but what if it's placed on a trickle charger? Will that prevent the breakdown process? I ask this because i hate wasting money, I would like to buy it, keep it on a trickle charger, and have it ready in the event of a failure.
  6. Britprius
    5,194
    1,921
    If you trickle charge it, it will be fine for a very long time but really because of the very low self discharge rate of the Exide battery (3% per month) charging overnight once a month should be fine.
    John (Britprius)
  7. Prius2U
    Prius2U New Member
    Dayton, OH
    Original battery in 08 was 56k. Mainly due to local driving. Almost 5 years exactly worth of time.
  8. srivenkat
    srivenkat Active Member
    596
    93
    IL
    Just FYI- The original Panasonic 12V in my 2007 TCH is still doing fine after over 7 years of service. I have a feeling it will last another 3 years or so. Replacing a battery every 4 years seems like it won't be good environmentally speaking :)
  9. Patrick Wong
    18,200
    6,497
    That is fine if you are alert and can assess when your battery is about to fail so that you can take action at that time; or if you don't mind being stuck at an inopportune moment when the 12V battery decides to fail on you.
    kenoarto likes this.
  10. kenoarto
    398
    Chicago, IL
    I very much support the eco thang, but how exactly does one get a "feeling" for a battery other than it failing via the many well documented ways documented here at PC? Does "feeling" mean: living with poor mileage and false warning codes or just total non-starting? 10 years ain't gonna happen, I'd be willing to bet BIG bucks on that!
  11. usnavystgc
    3,159
    990
    Tucson, AZ
    If you take care of it, ten years + is achievable. My Gen 1 aux battery lasted 10+ years.
  12. Patrick Wong
    18,200
    6,497
    Yes, it is possible if you keep the 12V battery charged up and avoid driver error. This includes fully charging the battery 2x per month if you log low miles, never allowing a door to remain open or an interior light to stay on when the car is IG-OFF, etc.
  13. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    I just replaced my OEM 12V (8.5 years old) a couple of weeks ago with an Exide Edge AGM battery (There was no way I was going to buy a yellow top Optima after all my trash talking). The original battery was still functioning adequately but I was experiencing an issue with the SKS system when locking the car with the black pad by the door handle. The car was sounding one long beep when I pressed the pad on more than one occasion, which it's not supposed to do. And no, I didn't leave the key fob inside the car. Since replacing the 12V battery, this has not happened again.
    However, I changed the 12V mainly because another Michigan winter is slowly approaching (sigh) and the almanac predicts it will be a very cold one. It took me 30 minutes to swap out the 12V in ideal conditions - in my garage with all my tools on a delightful 75° day in bright sunlight. I didn't want to be stranded and faced with swapping it out on a cold, dark night in some godforsaken place in early 2014.
    Daves09prius, usnavystgc and kenoarto like this.
  14. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    2008 prius. 46k miles. In florida. The last three years very low miles as I lost my job and my health suffered to the point I probably would not work again. That has been the case so far. I suppose my battery finally crapped out because of the extreme low driving of the car. The last time It had set for 3 days.
    I did put in a yellow top Optima and am very happy with it so far. My scan guage 11 says it is at 13.8 when running along. With brakes and lights and all accessories on it drops to 13.5 . Good enough for me.
    I will try to drive it around more to keep the battery happier.
  15. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Get a pulsing type battery maintainer/desulfator, and keep the car plugged in when not in use. End of concerns. My car sits for 2 weeks sometimes, and no problems with this method.
    usnavystgc likes this.
  16. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Sounds very similar to mine Jadz. I just replaced the original 12V battery in my 2005 Prius a couple of months ago, near the start of our (southern hemisphere) winter. Mine was date coded Nov-2004, so it also lasted a shade over 8.5 years.
    I was watching it fairly closely near the end. It had been reading a little bit low for quite a while (12.1 acc / 11.8 ig-on) but near the start of winter it started going downhill pretty fast. One morning it was down to about 11.3 acc/ 10.5 ig-on. It still started and ran fine though, but that morning I drove straight to the parts store and bought a new one.
    I've got to say, even right to the end it didn't cause me any issues. I didn't even notice a glitch in my 4.2 L/100km (56 MPG) average.
  17. ursle
    ursle Gas miser
    1,049
    192
    NH
    So, the question is, (for the 5 year and older oem users) when replacing the 5 year old oem battery what was your mpg average and after replacement, what is you mpg average?
  18. usnavystgc
    3,159
    990
    Tucson, AZ
    Mine didn't change.
  19. nh7o
    1,686
    340
    Hawaii
    It will depend on how the battery is failing. In the usual case the plates get sulfated and the internal resistance goes up, so it will look like it has very small capacity. If it starts the car at all, it will not take much charging current before the charger decides that it is full and goes to float mode. That won't make any difference in the MPG as the failing battery doesn't represent an increased load.
    If the sulfation has progressed to the point that there is an actual plate to plate short, then the battery will never reach the high voltage that allows the charging circuit to switch to float mode. Then the charger will waste lots of current trying to prop up the voltage, which is just going to heat in the failed battery. In this case the MPG will suffer as the 12V charger system will overheat, and that really cripples the performance of the car.
  20. Poosey
    Poosey Junior Member
    16
    SW Florida
    Four and a half yearsin SW FLorida where we have had three months straight of 90+ degree weather with wife who enjoys leaving the interior light on. :mad: Replacing today MOF and going to find a less expensive alternative than $170 @ Batteries Plus if at all possible.
