Typical price on a 12Volt battery change at a dealer?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ETP, Aug 24, 2013.
  1. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    I gave my touring 2009 to my daughter and she had it towed yesterday to a dealer. The battery was dead and they charged her $300. Is this a typical charge.
    The car was starting by itself after she locked the car. LOL
  2. Prius_Cub
    Prius_Cub Member
    152
    60
    Radford, VA
    Sounds about right for a stealership. You could have bought one for about $125 or so from Advance Auto and installed yourself in about an hour.
    LG-AS695 ? 2
  3. Mendel Leisk
    38,982
    What was the breakdown, how much for the battery, and the labour, if it shows on the invoice and you don't mind?
  4. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    $300 does not seem out of line for a battery installed by a dealer.
    Merkey likes this.
  5. bisco
    49,811
    spot on.
    Merkey likes this.
  6. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Yes, it is the typical price for this overpriced part and labor from dealerships.
    Merkey likes this.
  7. ETP
    2,802
    1,170
    Auburdale FL
    She said the car would start at random tries and finally would not start at all. Started itself one time while outside the car.
  8. SteveLee
    645
    180
    North Carolina
    I
    How well versed is your daughter on the operation of the Prius? Is it possible she is hitting the Park button and getting out? If she is not also hitting the Start/Stop button to turn off the system then the gas engine will cycle on and off as needed to charge the HV battery that powers nearly everything after the system is READY. The engine coming on could be interpreted by some as "the car starting by itself".
    If this scenario proves to be true then your daughter doesn't really know the system is on unless the engine is running, like most other cars on the road. But, as we know, the car is on when it is READY. Also in that event, the 12V battery may not necessarily have needed changing just because she had it towed because the ICE was cycling on after being left in Park but still in the READY state.
    Merkey likes this.
  9. Mendel Leisk
    38,982
    Maybe "breakdown" is a Canadianism, LOL: I was wondering what the bill said: how much was for the battery, and how much was the labour to install.
  10. ETP
    2,802
    1,170
    Auburdale FL
    I don't think you can lock the car with the FOB in operate mode. But I will ask! I know my two new ones are very picky on when you can actually lock them.
    I think I have used the park button once in all 3 cars.
  11. SteveLee
    645
    180
    North Carolina
    I
    Also, I have seen references to starting by itself as a result of a lose battery connection. The negative battery cable where it connects to the body is commonly reported as a lose connection.
    Britprius likes this.
  12. wtfjr36
    wtfjr36 Junior Member
    63
    Ormond By The Sea FL
    In April of this year we paid the local Toyota dealer $185 for the new 12 volt Prius battery including installation & a free car wash.
    Sounds like you were had by your dealer, unless that pricing included the tow as well ?
  13. SteveLee
    645
    180
    North Carolina
    I
    Sure would like to see a copy of the invoice, or a picture of the battery, or at least the battery make and model. I don't doubt you, just would like to know exactly what they used, their price for the battery itself and then the labor.
  14. wtfjr36
    63
    Give me your EM & I will send you a scan of the invoice ?
    Bill in FL
  15. SteveLee
    645
    180
    North Carolina
    I
    Ok, I PM'd you.
  16. wtfjr36
    63
    Scan sent earlier.
    Good luck !
    Bill in FL
  17. SteveLee
    645
    180
    North Carolina
    I
    Thanks Bill. It is indeed a genuine Toyota battery for Prius w/SKS. What is interesting is your Daytona Toyota dealer charged $185 for the battery, gave a $10 discount, only charged $20 for installation and then gave you a free car wash. I would advertise for this place. Ahh, I think I just did.
