Tyre pressure warning
Discussion in 'Gen 5 Prius Main Forum' started by chris johnson 2, Feb 3, 2025.
  1. Trollbait
    12,818
    The patch and plug is a patch that has a stem that is inserted into the hole. Your shop likely uses them while simply calling them patches.
    Plugs are technically just for temporary repairs, which is why the shop won't do them. I have had them last years though, with only one failing to a slow leak.
  2. VelvetFoot
    VelvetFoot Senior Member
    1,408
    545
    New York State
    2026 Prius
    They do take them off the rim however.
    They insert the plug/patch from the inside? That would make sense.
  3. Trollbait
    12,818
    Yes, though they would do the same for a plain patch for a hole in the tread. The patch & plug could leave something that looks like a plug on the outside if you want to check.
    VelvetFoot likes this.
  4. Gokhan
    Gokhan Senior Member
    6,714
    2,661
    Paramount CA
    #64 Gokhan, Oct 8, 2025
