Ugh, I think my 12V battery's dying
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Apr 2, 2008.
  1. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    life depends on a lot of factors
    I think it really depends on the car, its underhood temps, the climate and the quality of the battery. One of my friends who used to live in the Los Angeles area mentioned that on both their Mazda Proteges, they'd go through car batteries every 2 years.
    The OEM battery on my former 02 Nissan Maxima IIRC lasted <3 years. I'm pretty sure I never deep discharged it either, esp. since it automatically shuts off all interior lights including map lights after 30 mins. I ended up having to pay a prorated replacement fee for the battery + diagnosis of the probs I was having.
    The one on my 04 Z (bought Sept 03) luckily is still ok.
  2. Flying White Dutchman
    4,376
    314
    :cool:2005 prius so a little over 2 years old
    thats normal for a prius battery:cool: SKS?:D
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    They do, you have to purchase an adapter kit for it for the vent tube, but a google or Priuschat search will turn up the info you need.
  4. Walker1
    Walker1 Empire
    911
    FL
    I thought the 12 volt battery was a routine maint. item & not covered under the factory warranty. How did you get a free bat. out of the dlr.? What is "Kragen" barnd, the part #, & where do you buy one? Also, I have been told that the 12 volt bat. in our cars is like a marine battery.
    One morning I was going to work & it was dark so the headlights were on. I got stuck in an accident stppage for about 45 minutes and I watched the sreen show the bat. going down to almost nothing. I learned fast not to use any accessories as they drain both batteries down when sitting in traffic. In that instance I shut the lights & car off until traffic started moving again.
  5. Walker1
    Walker1 Empire
    911
    FL
    I was under the impression that the 12 volt battery in our cars was a deep cycle type. Are you stating it's just a plain old every day 12 volt car battery?
  6. Walker1
    Walker1 Empire
    911
    FL
    Here in S. FL the average car battery lasts about 2 yrs. I started using battery tenders 4 yrs. ago on 1 car that sits a lot & so far the bat. is still good after 4 + yrs. If anyone is getting 7-8 yrs. out of a stock battery I'd love to know the secret to that longevity.
  7. Tideland Prius
    16,681
    I don't know. Our camry lasted 5 years and no battery issues.
    Update: I managed to steal... err borrow a volt meter from my old work place. The battery (after running the car for over an hour) was reading 12.28V.
    So the battery SOC seems fine. It just doesn't hold the charge maybe?
  8. Patrick Wong
    18,210
    6,526
    Your battery voltage is low. 12.6V or better is what you would expect from a fully-charged battery after the surface charge is removed.
    It really appears that you need a new 12V battery.
  9. richard schumacher
    7,686
    1,068
    United States
    Sure, radio only, and a battery less than four years old. Try it again with everything turned on and an old battery and let us know how long it lasts.
  10. Walker1
    Walker1 Empire
    911
    FL
    Re: My 12V battery died- how to jump?
    On my 2006 there is a good size unpainted threaded stud with a nut on it very close to the fuse block just above the top of the cover near the rubber strip. All they're saying is not to ground to a painted part of the car. I'm curious as to one would get a jumper cable end into the small spot in the fuse block. There sure isn't much room in that little square area.
  11. hschuck
    hschuck Member
    385
    bay city, ca
    The positive jumper cable is to be attached to the tab that is next to the stud inside the cover in the fuse box. You are probably thinking of attaching it to the stud and you are right that a normal jumber cable will not fit in the cavity with the stud.
  12. Tideland Prius
    16,681
    What do you mean surface charged removed? I just touched the terminals of the battery (yes, the one in the hatch, not the quick access one under the hood). Was I supposed to do something before checking the voltage?
  13. Tideland Prius
    16,681
    Why would I do that? I never leave it in IG-ON. I don't need the fan running or the power windows/mirrors active. Never left any car in ON either. ACC for the radio that's it.
  14. Patrick Wong
    18,210
    6,526
    The Prius DC to DC converter maintains a voltage of ~13.8VDC on the 12VDC bus when the car is READY. The 12V auxiliary battery is charged while the car is READY.
    Immediately after you turn the car to IG-OFF, if you measure the voltage across the 12V battery, it will be at or very close to the charging voltage of 13.8V. However as you continue to watch, the voltage will decline. After about 30 min. it will be stable.
    At that point, the voltage should be 12.6-12.8V if the battery is fully-charged. If much lower than that, then this shows you that either the battery needs more charging, or else its capacity is diminished due to age.
    The symptoms that you posted at the beginning of this string are characteristic of a battery that is about to fail.
  15. Tideland Prius
    16,681
    My voltage reading was with the car off for about 10 mins.... it's definitely dying then.
    The next step now is.. what to do lol. should I just mention the symptoms (and let the dealer figure out the dead battery) or should I tell them that I think the battery's dying and ask that they double check.
  16. Flying White Dutchman
    4,376
    314
    the prius battery is simply to small.. and charging it really good takes to long
    so when you drive short and leave the Car standing long and have the sks system....
  17. Patrick Wong
    18,210
    6,526
    Well, you can either have the dealer replace the battery for ~$300 including labor; or you can buy the battery from the dealer's parts dept for ~$160 and DIY.
    If you DIY you'll have to remove the brake power supply that is in the way, and also the ventilation duct to the traction battery.
    When removing the fuse block on the positive terminal you will find that the red cover is hard to remove. Just bend the cover up enough so that you can loosen the terminal nut.
    You will also probably find that it is easier to remove the negative battery cable where it attaches to the car, rather than try to remove the cable from the battery. Don't forget to unplug the rubber ventilation hose to the battery, and reinstall that on the new battery.
    Good luck.
  18. Tideland Prius
    16,681
    :eek: errr..... definitely out of my league for a DIY project :(
  19. richard schumacher
    7,686
    1,068
    United States
    In that case tell the dealer to start diagnosis with the battery. It should save you several bucks worth of their time.
  20. Tideland Prius
    16,681
    Will do. Thanks!
