Uh oh. '05 Grinding in D/N won't move
Discussion in 'Gen 2 Prius Technical Discussion' started by miscrms, Nov 14, 2011.
  1. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    I'm not sure what the noise is, but it sounds expensive :(
    Backed out of parking spot, started making an awful clunky grindy noise. Put in drive and more noise but no go. Put in neutral, still grinding but stopped after a minute. Pushed back into spot, waiting for AAA. Interesting it would not go into park from N until the grinding stopped. No lights on dash interestingly, except the snakes chasing your car (traction?) light flashes intermittently while it's grinding.
    Any thoughts appreciated!
    Rob
  2. miscrms
    2,079
    527
    Phoenix, AZ
    Seems to grind as long as engine is running. Won't go to park from neutral directly, have go to drive then park.
  3. miscrms
    2,079
    527
    Phoenix, AZ
    Tow truck driver found two pieces of some sort of greasy metal ring on the ground, said they looked like part of the axle halfshaft. After that I noticed there was grease spattered around inside the right front wheel well.
  4. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    How many miles on the odometer?
    GL, I hope it isn't too expensive to fix.
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Did the car receive any front end/wheel damage when it became salvaged?
    +1 on GL
  6. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    If it is a problem outside of the transaxle, that would be the best case scenario. Could be that your CV bombed.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    The noise in neutral confuses me. Maybe the part just continued to turn for a while until stopped by friction.
  8. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    Yup, sounds like a CV joint. They are not too bad. Easy to get to, easy to replace. I wonder if it's a case of a failed boot not noticed. I inspect Pearl's at every oil change.
    If it was in an accident (front end) the CV probably got "tweaked". Let's hope that didn't translate to the HSD housing by the half shaft.
  9. jacen17
    jacen17 Junior Member
    Massachusetts
    been reading this forum for several years - first post. I'm having this same issue with my 2004 (220k miles!) - put the car in drive or reverse, doesn't move, grinding noise from under the hood. Happened for the first time today in MA on a very hot day. No, I have never changed the transmission fluid in the three years I've owned it and don't know anything about its maintenance history from the previous owner.
    I know this is a very old thread but thought somebody else might be able to point me in the right direction. I can try to pull the codes I just need to buy a code reader for the Prius.
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    There have been a few trans chain failures in the last 13 years on this site very few but a few. It will make an ungodly thrashing sounding noise I would imagine.
    Did it launch a code on the dash maybe the red triangle of death? No codes on the dash no codes launched. This will probably not throw a code as its mechanical.
    A few differential failures also. Both of these are from poor fluid maintenance or just having the snot beat out of them.
    Also a few clutch pucks too there's a little spring loaded plate that connects the trans to the engine. Its to smooth out impulse noise between the engine/trans connection. They break. A few have failed but again very few.
    Trans damage/failure sometimes happens when you get a trans fluid leak. if you park in the same place very day good thing to take a look at the spots it leaves on the ground.
    Easy way to exonerate the trans is to dump the trans fluid. Before that open the fill hole on the side of the trans and stick you finger in the hole the fluid should be right at the hole. if not check the sides of the differential where the inner cv joints enter the trans is there fluid leaking out of that area? Thats kinda common to with bad cv joints.
    Pull the trans fluid If its got chunks of metal stuck to the magnet bolt there you go.
  11. jacen17
    Massachusetts
    This car has had the red triangle since I bought it due to an issue with the headlight level adjustment that I haven't bothered to fix - because of this I don't know if another error has popped up.
    However I did jack up the car and could immediately see a problem - fluid leaking from the CV boot on the passenger side tire. Two of the bearings actually fell right out when I removed the boot! The CV joint was misaligned so was now rubbing against the chassis and that's what was causing the noise. So obviously need to get the CV joint replaced.
    I still don't understand why the tires weren't spinning, at least the driver side tire that is undamaged. Would the traction control system prevent power from going to the wheels if it detects the wheels aren't spinning? I did see the traction control front panel indicator light up. I disabled traction control, still no power to the wheels.
    I'm getting this towed to the mechanic, I just hope the CV is the only issue and there isn't something larger wrong with the transmission - like I said, poor history of maintenance in this area.
  12. edthefox5
    10,096
    4,837
    Clearwater, Florida
    yep. The bad thing is since the cv joint is so jacked up it tends to wobble and beat up the differential....so I would still have the mechanic pull the trans fluid its cheap and it needs it.
    Here's the very bad news if you have a red triangle that the Red Triangle of Death RTOD its a fatal code the headlight adj will not throw
    that.
    Its launching the traction control as you surmised. But is imperative you pull all the codes it has thrown by using a hybrid capable code reader. If you come back and say it has no codes your not using a HCCR.
  13. jacen17
    Massachusetts
    Thanks, Ed. Just ordered a mini VCI cable I will scan the codes in a couple days.
  14. jacen17
    Massachusetts
    So it took about three hours but I got the error codes (attached here). I'm not seeing anything major, just P0456 and P0556 - nothing related to transmission or battery. So I think that is good news.
    How sure are you that the RTOD will not illuminate because of the headlight leveler assembly issue? There is also an icon on my LCD screen indicating the assembly is broken, and I was told by the previous owner that's also why the RTOD is lit (for whatever that is worth).
  15. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    When you click on the snowflake icon next to P0456 code, what info is displayed there?
    edthefox5 likes this.
  16. jacen17
    Massachusetts
    When I click the snowflake a new window opens with a table that is blank (has no information in it).
    The title is "P0456 Evaporative Emission Control System Leak Detected (very small leak)
  17. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Usually the table will have more information that points toward the cause.
    I'd try and reconnect the Prius and tech-stream and see what you can get.
    If there is a snowflake, there is more information to help determine the next steps(y).
    edthefox5 and jacen17 like this.
  18. jacen17
    Massachusetts
    I couldn't think of a less intuitive symbol of "click here for more information" than a snowflake! Curious why that's the icon. Anyways I did as you suggested and now I see the additional information, I have attached the detailed logs, I'm not really sure what I'm looking for.
    On this new scan, C2318 also popped up, but I believe this is just because my auxiliary battery voltage was low - a few minutes later, my car died, and its currently on the charger...
    Thank you for the help it's really appreciated.
  19. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    The reason for the snowflake choice is the software is collecting and sharing "freeze frame" data;).
    If you look at the top of your screen shots, you'll see what it is sharing as time lapse:).
    I'm not the most adept at interpreting techstream, but see if there are any differences amongst the time lapse. Another option is to pull the 12v lead for a bit and see what resets and returns. Always an option to see what remains(y).
  20. jacen17
    Massachusetts
    Just to close on this, the issue was just the CV joint. Replaced and back on the road! Thanks everybody for the help.
    TheLastMojojomo, SFO and Raytheeagle like this.
