UK / Europe Prius 2 Coolant Change
Discussion in 'Gen 2 Prius Technical Discussion' started by Lee Tomlinson, Aug 10, 2024.
Tags:
  1. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    Was the radiator full to start with?
    I got 3.8 litres out when I did mine. Never figured out why it was so little. I eventually got 3.8 L back in but initially only got 2.8 L in.
    #21 dolj, Aug 19, 2024
  2. Lee Tomlinson
    Lee Tomlinson New Member
    London, England
    ----UK----
    I didn't check the level in the radiator actually. The tank was at the full line, but I am not sure about the radiator before I started (it is full now).
    I was also wondering whether you need to open the radiator cock and engine block at the same time. I did one and then the other. Maybe that creates an air lock or something?
  3. dolj
    dolj Senior Member
    8,652
    4,403
    Not sure. I did the same, I drained the majority from the radiator before opening the engine block drain. Very little came out the engine block.
  4. Lee Tomlinson
    London, England
    ----UK----
    I guess I'll try doing both drains at the same time. Also setting the heater to high temp first.
    If I can only get out 3L again, at least I've changed 3L twice. If so, I'll just wait a while and just drain the radiator a third time. That is quick and easy. Don't even need to jack up the car.
    Sure there must be a proper way to drain all 5.3L in one go, though.
  5. dolj
    dolj Senior Member
    8,652
    4,403
    As long as the radiator cap is off, it shouldn't make any difference.
    Lee Tomlinson likes this.
  6. Lee Tomlinson
    London, England
    ----UK----
    Not sure then why I only got out 3L out of the 5.3L... Unless it's because I didn't set the heater to high temp before doing the drain
  7. Mendel Leisk
    42,364
    Worth noting: you’ll never get the specd volume, some will always hang up in knooks and crannies.
    but you shouldn’t be getting significantly less than what others are getting, following the same procedure.
  8. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Some coolant always remains in the compartments and pipes.
    To drain as much coolant as possible from the engine systems, I raise the rear of the car while tilting the front of the car down.
    To fill the engine system with coolant as much as possible, I raise the front of the car by driving onto a hill. Or two hills))
    Illustrations from the Internet, all matches are random
  9. Lee Tomlinson
    London, England
    ----UK----
    Thanks. Didn't try raising the rear of the car. But I guess that makes sense!
