UK rear fog light (red)
Discussion in 'Gen 4 Prius Main Forum' started by 1980s_john, Jan 20, 2019.
  1. 1980s_john
    1980s_john Junior Member
    43
    22
    England
    Business Ed. Plus
    I have been looking at adverts for a 2016 Prius, and saw the attached (now sold). Note the fog light on the bottom right of the bumper. Was this a Toyota UK spec car, or was this an import that someone had to mod to get through the MOT?
    Regards,
    John
    (nb a switchable rear red fog light is mandatory for UK registered cars. A MOT test is needed on all new cars once they are 3 years old then on each year after.)
  2. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    Not sure what that is. Here's my 2017 UK Prius with the fog lights on and off for comparison...
    alanclarkeau, ice9 and 1980s_john like this.
  3. 1980s_john
    43
    22
    England
    Business Ed. Plus
    Thanks Professor, yes that looks normal - one I saw must have been an import.
    Regards,
    John
  4. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    That fog light is not a standard fitment and the 66 reg is not 3 years old until Sept 2019 so if the car has a MOT certificate or it's advertised as 3 years old, then it's definitely an import.
  5. ice9
    ice9 Active Member
    581
    345
    norfolk va
    2018 Prius
    That looks like it could be an effective safety feature. I have two questions:
    1) Are there any range/visibility improvement specs?
    2) Do you know if it is available in the states?
    The Professor likes this.
  6. The Professor
    598
    809
    UK
    Excel
    Sorry - no idea to both.
    alanclarkeau likes this.
  7. ice9
    ice9 Active Member
    581
    345
    norfolk va
    2018 Prius
    Mfr? Part no? Maybe I can look it up.
  8. The Professor
    598
    809
    UK
    Excel
    These are standard factory fit in the UK. There are some people on here that have access to the Toyota part numbers for different locales, so hopefully someone will be able to help.
  9. ice9
    ice9 Active Member
    581
    345
    norfolk va
    2018 Prius
    I just found them on the web. OEM part, but I haven't identified the OEM part no. yet.
  10. ice9
    ice9 Active Member
    581
    345
    norfolk va
    2018 Prius
    I just spoke a to local dealer about installing the EU / UK tail lights here in the states. He indicated that it wouldn't be a problem so long as they had the proper SAE markings. The US tail lights are marked "SAE AIP2R(2)T" for the upper assy, and "SAE AS(2)114" lower assy (both left and right tail lights).
    Do your tail lights have these markings?
    See attached photos. Note: The image of lower tail light assy (2nd image) is rotated 90 degrees cw for readability.
    The marking for the bottom left tail light assy is inscribed inside the bottom left side of the assembly (inside the bottom right side for the lower right tail light assy).
    The SAE markings can be more clearly seen when viewed at night (or in a darkened garage) using a high intensity LED flashlight.
    #10 ice9, Oct 11, 2019
  11. ES95
    ES95 New Member
    Lithuania
    can you show me dashboard picture when rear fog lights are turned on?
  12. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    I would like to add rear fogs. Do all the fogs come on together or independent front to rear?
  13. PaulDM
    PaulDM Active Member
    616
    320
    UK
    2022 Prius
    Excel
    Independent front and rear. Fog switch position one is front. Then push switch to next setting (switch will spring back to setting one ) that activates rear.
    Ryder99 likes this.
  14. PaulDM
    616
    320
    UK
    2022 Prius
    Excel
    I really can’t see why they have done that on a gen4. Unless there was a fault. Front and rear fogs are standard across the range made for the UK.
    Mostly due to the fact that since April 1980 it is a legal requirement all cars have to have rear fogs fitted by manufacturer before they can be sold here. Front fogs are still optional.
    #14 PaulDM, May 5, 2022
