ukr2 in Rochester, NY got his PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Mar 14, 2012.
  1. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    To minimize emissions, once the ICE is started cold it must go through the warming cycle.
    I can see your frustration of accidentally triggering the ICE by going over the threshold in a short trip. I think Toyota should relate to this.
    I can think of adding a simple warning indicator that you are approaching the threshold, like for example, the EV indicator (this green car icon) turning from green to yellow, you can then hold the pedal or back off a little bit to avoid triggering the ICE.
  2. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    I wonder, what EU version of PiP, which has EV City mode button, will do with that button, that doesn't do with US PiP. Maybe exactly that?
  3. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That's actually secondary, though still a high priority. The primary purpose has always been emission reduction. This has been what sets Prius apart from many of the other hybrids. It intentionally consumes gas for the sake of maximum cleansing.
    MPG while in EV mode with the automatic switch to HV for warm-up is still outstanding. There's also some EV replenish that occurs as a result of the engine running. So unless you drive nothing but short-trips with hard acceleration, the gas usage is somewhat of a wash anyway.
  4. john1701a
    12,818
    5,303
    58
    It would be interesting to see the data gathered from the early model driving. I suspect that was a major contributor to the reason for not offering that here. In fact, that was why we got the HV/EV button.
    Also, keep in mind that Volt doesn't offer an HV/EV button (aka: "hold") here but does in Europe.
  5. andi1111
    andi1111 Member
    270
    63
    EU
    2012 Chevy Volt
    I think EU PiP also has EV/HV button, but it lacks PWR button.
    Edit:
    2 people like this.
  6. LenP
    LenP Member
    257
    69
    Morris County, NJ
    Does the EV city keep the ICE from coming on at all, but then what about heat? What would its use be over EV/HV?
  7. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    As far as I understand, the City EV button is raising the threshold above it the ICE starts, so giving moe flexibility of EV in city driving. It is not a 'hold' button.
  8. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I left the Dealer today and noticed that he turned off my Headlights.
    Then I noticed that the Dash Dimmer Dial (Instrument Panel Light Control Dial) didn't affect the Dash Light like when the Headlights are ON.
    My Headlight switch has 4 positions of OFF - DRL - Side Marker - Headlights.
    In the OFF or DRL positions, when the Dial is clicked up to the top, the Dash Brightness is Max. When the Dial is clicked down off MAX, the Dash Brightness stays Max.
    When the Dial is almost to the botton, the Dash Brightness snaps to dimmer, not variable.
    In the Side Marker or Headlights positions, when the Dial is clicked up to the top, the Dash Brightness is Max. When the Dial is clicked down off MAX, the Dash Brightness starts at dim and varies until when the Dial is at the botton, the Dash is Dark.
    Strange the Dial works different, based on the Headlight Switch.
    I also wish I had an AUTO Position, that would keep the Headlights and their energy OFF until nightfall. I hate wasting the kWhs.
  9. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I was testing the Above Dimmer Dial in the Driveway.
    After I had left the car for an Hour, I noticed the Headlights were on. GREAT !!!
    I had changed the Headlight Timer to Zero a week ago that had been working.
    So I started the PIP, then turned it off, opened the door and the Headlights turned OFF, like they are suppose to.
    With the car off, if I change the Headlight Switch from Headlight to another position and back to Headlights, they come ON. AND STAYED ON. DAMN.
    I started and stopped the PIP and the Headlights went OFF. Confusing !!!
  10. devprius
    devprius /dev/geek
    979
    291
    San Francisco Bay Area, CA
    Pretty much every car I've owned since the early 90's has operated the dash lights like this.
  11. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Yup, same on the standard liftgate, messing with the headlights seems to over ride the auto off.
  12. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    $11.5k trade-in on a 2007 is a good price. Private party generally gives higher as we know but it wouldn't have been higher enough to be worth the hassle in this case, IMO.
  13. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Dave,
    Why does the Dash Dimmer Dial operation change based on the position of the headlight switch?
  14. devprius
    devprius /dev/geek
    979
    291
    If your headlights are on, then it's presumed to be dark outside. So to preserve your night vision, the dash lighting can be dimmed to a comfortable level. Whereas if your headlights are off, then it's presumed to be day out and you need the dash lighting to be at it's brightest because daylight would wash out the light. The dimmer dial allows you set a comfortable level for night driving, and when your headlights are off, reverts automatically to full on brightness for day use. There is an override setting on the dial that allows you to have your headlights on and full dash lighting. This is usually needed when driving during the day in conditions that require your headlights be on (certain highways for safety, in the rain, long tunnels, just before dusk or right after dawn).
  15. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    Headlights off is interpreted as daylight drive, so full brightness. Headlights on - night driving so dimmer controlled.
    In my CTh I have Auto position, when I get into a tunnel the dash is automatically dimmed together with headlights on.
  16. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Finally, my 1st Fillup.
    Added it to the MPG Spreadsheet:
    https://docs.google.com/spreadsheet/...WDBUdGc#gid=10
    1045 miles, 8.875 gallons, Metered kWh=187.9
    EV Display=161 kWh, 8 Gal, 13.5 Saved, EV%=59, 621 miles, HV%=41, 423 miles
    Since HV Miles includes the EV miles driven when in HV Mode, the HV MPG clouded.
    But then not all the EV miles are from kWh energy. Some are from Regen.
  17. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    That's some serious logging
    Welcome back
  19. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
    Lots of cool data.. and nice driving.. impressive EV% for a PiP.. seems like an ideal car for your patterns.
    Too bad there is not autologging like we get from onstar in the volt. Voltstats.net is great for us, though its not as detailed as your log, its nearly zero effort.
    Did you consider a android phone, bluetooth and troque? Its what I use to log in my VOlt.. but for the PiP you should get a more more interesting data. I used a old phone, a $20 adapter and $5 for torque.. Great since I wanted a cheap solution for occasional more detailed logging.
  20. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
