ukr2 in Rochester, NY got his PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by ukr2, Mar 14, 2012.
  1. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Thanks again Tracksyde for backing up the MPG sheet.
  2. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Gathering the data is very basic.
    I take photos of the 7 displays before and after each driving segment and the Kill A Watt values at home and at work. Then enter the data of the photos to Excel.
    I started it the day I got the PIP March 14 and now can't stop !!!
  3. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    No problem.. but I should be thanking you for maintaining and keeping watch over the spreadsheet.. so thank you!
  4. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Since getting my PIP March 14, I've been using the lock every time I charge at home and work. Using the Master Tumbler lock is very easy. It may not be necessary, but it's routine now.
    Is anyone else locking their handle each charge?
  5. mrbigh
    3,686
    699
    Long Island, NY
    I liked it so much that I adopted the locking procedure to. Instead I use a keyed padlock, much easy to unlock in the darkness of the early morning and I carry the padlock key with my fob in the ring.
    This is a much more elegant and practical solution that others I had see and a few $$ worth.
  6. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    I use one of those locks with the 3 number combination too for when I plug-in in the street where I live rather than my garage. It's from a piece of luggage I bought, so nothing great or expensive but it gets the job done.
  7. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I drove 200 miles with a full charge, used the AC and got 58 mpg.
    Then drove back with No Battery, used the AC and got a TRUE 51 mpg.
    Averaged 54 and 55 mph.
    Very pleased !!!
  8. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I was escorting a Senior Adult Group to the Outer Banks, North Carolina, when at Bodie Lighthouse a Sea Glass Pearl (green) Prius Plug-in, just like mine, drove in the parking lot.
    FIRST PIP I've seen and it was Just like mine.
    I knocked on the window, scared the pants off the guy and introduced myself.
    He was from the Chesapeake Bay area.
    I told him about PriusChat.com and told him to signup and post his info.
    And the Lighthouse was exciting too !!!
  9. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    OK, we need to find a way to keep the ICE from starting when not wanted !!!!
    Twice today I turned onto a 45 mph road and didn't watch the HIS, and the ICE started.
    It wasn't needed.
    I was only going 2 miles to and from lunch.
    When in EV, if the gas pedal isn't pressed to the Floor, I DON'T want the ICE on.
    Can someone figure it out?
    Do we need a Toyota Engineer?
    Is there a Toyota Engineer listening???
  10. bisco
    51,910
    are you having a lot of trouble with this? it hasn't happened to me.
  11. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Today was NOT my day. I reset EV2, when I wasn't filling up. DAMN !!!
    For some reason, EV2 displayed before EV1, I took a photo of the data and reset it without seeing it was EV2, not EV1.
  12. bisco
    51,910
    do u mean trip a and trip b?
  13. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    I use Trip A and EV1 for driving segments and reset them after a charge.
    I use Trip B and EV2 for Fill-up data and reset them after a gas fill-up.
    I've been taking photos of each of the displays before and after each driving segment and fill-up and then transfer the data to Excel since I got the PIP March 14.
  14. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    Nasty. :eek: I've had that same fear. But so far...
  15. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Me too! What makes it worse is that we rarely need to fill up, so the routine of taking pictures/notes of the various trip odometers and ratios never really sets in. I may need to create a cheat sheet for myself so I remember what to do and what not to do when I finally go to a gas station. :D
  16. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Well, since I reset EV2 by mistake, I decided to get a fill-up early.
    OK now.
  17. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    After a Charge, when you press DISP on the steering wheel, why does the EV Display Ratio 2 display first?
    Why not EV 1?
    I checked the Manual, but can't find why.
    Also, I have a Kill-A-Watt to show me each charge amount.
    Is there a Display that shows the kWh added?
    Is it per charge? Is there an Accumulation Amount?
    Where in the manual is the info?
    For those that got to test the Pre-Production Plug-in vehicles, who were the engineers that sought your feedback? Are the engineers still around?
  18. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Have you noticed that in EV when the battery is 0.1, it stays there a long time?
    Also, we know that when the Fan is turned on, the Battery drops 1 mile and when you turn the Fan off you get the mile back?
    Well, when the battery is at 0.1, you don't get the 1 mile back, but it stays at 0.1 for a longer time.
  19. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    All I notice is that once I get to 0, there's no more EV for me until the next recharge.:mad:
  20. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
