Unable to complete Linear Valve Offset after actuator replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by farmermac, Apr 21, 2026.
  1. Turniptthebeets
    Turniptthebeets New Member
    Which Toyota dealer is offering actuators for $1,250?
  2. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Prices have gone up since last summer. Was able to order one in the low $900 new from Serra Toyota last summer using the 25% sale. They are now ~$1400 before applying the 25% off sales. Like everything else we import into this country, we like winning by paying more money disguised as tariffs.
  3. Turniptthebeets
    The comment I was asking about was
    I asking about the comment from JC91006‘s a week ago.
  4. farmermac
    farmermac Junior Member
    46
    You mean tremendous tariffs! Do you know how often these sales pop up?
  5. JC91006
    16,933
    8,643
    they pop up often, a few times a year. But not always at 25%. It ranges from 10% to 25% and they typically last a week once they sales pop up.
  6. farmermac
    46
    Thanks. Curious when you popped the actuator in - did you go through the whole techstream bleeding procedure before calibrating the actuator?
  7. JC91006
    16,933
    8,643
    yes you have to go through the bleeding procedure using techstream first. It's the easiest way to do it, it's a step by step prompt and really can't mess it up.
    I've done it manually but the feel of the brakes afterwards made me second guess my results. So I would suggest making your life easier and just use techstream to do it.
  8. farmermac
    46
    Ive done the bleeding procedures on 3 different actuators, and it completes successfully..The brakes certainly dont feel like there's any air in them. I got 2 used units with the old part number (ends in 50) and for the third time paid 450$ for a updated, newer unit (ending in 51), but that is also used. Upon plugging it, prior to performing the techstream bleed, but turning the car on i was dismayed to see the linear code stored on this unit as well, and not going away after bleeding it using the techstream procedure.
    I guess what i am wondering is, did you have lights on/codes prior to bleeding the unit with your brand new one, or was it error free out of the box?
  9. JC91006
    16,933
    8,643
    I don't think there should be any stored code on the unit itself. It would be stored on the car. Have you gone through the entire procedure of bleeding and linear valve offset calibration? I would go through the entire process regardless of the codes you have stored. And if you have a different 12v battery, try using a different battery in the car.
  10. xw20_driver
    xw20_driver Member
    118
    59
    PNW
    Serra Toyota just had a 25% off sale. My guess is the next one might be a national Toyota parts sale around Memorial Day. They are known to be slow and can take close to a month to receive your order when they get inundated during sales events and have to special order the part.
    Brake Actuator Assembly with Resistor #44500-47141 | Autoparts.toyota.com
  11. JC91006
    16,933
    8,643
    seems like all the Toyota dealers from the southeast participate on these sales. The fastest service will be from Tuscaloosa Toyota. So if other dealers are slow (World Toyota or Serra Toyota), you can order from Tuscaloosa
  12. pasadena_commut
    pasadena_commut Senior Member
    3,011
    937
    Southern California
    Which "Techstream" and cable are being used? Some of the cheapo VCI cables are known not to be able to perform all the functions, even if the (hacked) Techstream software itself could. Does the OP have an Autel MaxiAP AP200? Supposedly that is reliable for some brake procedures that don't work with those marginal VCI cables. Likely some of the other expensive scanners that shops have could also perform this procedure.
    JC91006 likes this.
  13. JC91006
    16,933
    8,643
    This is a very valid point. The cheap cables often have issues completing the tasks without losing connection
  14. Turniptthebeets
    I also tried with a innova 5610 v3 which is supposed to support bidirectional but got the same issue
  15. JC91006
    16,933
    8,643
    Did you replace it with a new unit or used?
