Unable to disable reverse beep using bluetooth OBDII
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dkarnes87, Jun 4, 2016.
  1. dkarnes87
    dkarnes87 Junior Member
    Hey all. Long story short, I picked up a bluetooth OBDII scanner and plugged it up, and tried following the instructions found on this forum. Only problem is, every time I run 3b ac 40, I just get a return of NO DATA. So here's how it goes:
    Connect using ELM327
    ATI
    >ELM327 v1.5
    at sh 7c0
    >OK
    21 ac
    >7c80361ac00
    3b ac 40
    >NO DATA
    21 ac
    >7c80361ac00
    In other words, everything works up until I tell the system to change 00 to 40, at which point it returns NO DATA and doesn't change the variable.
    Any idea what's going on here? For what it's worth, disabling the seat belt worked, so I know the adapter is able to send commands properly.
    #1 dkarnes87, Jun 4, 2016
  2. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Try 03bac40 instead of 3b. also leave out the spaces
  3. dkarnes87
    Just tried that, same result. Thinking maybe it needs hex format I also tried 003bac40 and that also didn't work. Same response. Very strange...
  4. ATLPrius44
    ATLPrius44 New Member
    I'm getting the same message
    Has anyone found a solution to this?
  5. MXBNDR
    MXBNDR New Member
    I'm also having this problem on a 2015 model. Seems to read most PIDs, but "3bac40" returns "NO DATA"
  6. pshadow
    pshadow New Member
    I
    The OBD 2 you're using may not be compatible with Prius. priusapp website has a list of OBD 2's that's compatible.
    I used Dr. Prius app, and Panlong OBD 2 to turn it off.
  7. bongsta213
    bongsta213 Junior Member
    32
    santa barbara
    anyone in los angeles area can do this for low price? or maybe for a case of beer??
  8. bisco
    52,821
    what kind of beer?
    RMB and Raytheeagle like this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    You’ll go to LA for beer:whistle:?
    And here I thought wine was a draw:p.
    RMB likes this.
  10. bongsta213
    32
    santa barbara
    40oz lol
