Unable to start car by pushing break but starts when fob is entered in slot
Discussion in 'Gen 2 Prius Main Forum' started by MarshaHertz, Jan 5, 2017.
  1. MarshaHertz
    MarshaHertz New Member
    Falls Church, VA
    I am unable to start my Prius by pushing on the brake as I have done the past 10 years, and it will only start if I put the whole key fob in the slot. Before I take this to the dealer wanted to know if anyone else has experienced this problem.
  2. nbojaxhiu
    nbojaxhiu New Member
    24
    kosovo
    Do you know there is a button under the steering wheel which enables/ disables this function? check if you have pressed it somehow by mistake. it happened to me also but checked manual and found out.
    51,155
    welcome?
    when was the last time you replaced the fob batteries, or tested the 12 volt battery health?
    kenoarto and MickyMatter like this.
  4. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    You should still have to press the brake even with the key in the slot, right? If not, that's very odd.
    If so, sounds like SKS is disabled or the fob battery is dead.
  5. MarshaHertz
    Falls Church, VA
    It actually was the button under the steering wheel that was accidentally depressed so I fixed it thanks to the previous reply! And no, when you put key in you just have to push power button and not the brake unless I am forgetting.
  6. bisco
    51,155
    yes, you're forgetting.:p all cars require brake depression to start, it's a safety lockout.
  7. bisco
    51,155
    nice call.(y)
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    My Gen 1 Prius does not require brake to be depressed when starting.
    Just turn the key and go.
  9. bisco
    51,155
    interesting. do you know if gen 2 is the same, if the fob is in the slot?
  10. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Whether fob in slot or out of slot, you must depress the brake to get into Ready mode.
    Confirmed in my 2005 (Gen 2) Prius that has smart key.
  11. Prodigyplace
    12,407
    11,682
    Central Virginia
    Same on Gen 4. I am pretty sure that is the case on my son's 2015 Prius v too.
  12. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    If bisco had said, "almost all modern cars require brake depression ...", he'd have been spot on.
  13. bisco
    51,155
    i should never make any definitive statements, you won't get elected that way.
    Prodigyplace likes this.
  14. dolj
    dolj Senior Member
    8,217
    4,187
    bisco for President.
    You never know, stranger things have happened. :ROFLMAO::LOL:
  15. bisco
    51,155
    ya, i couldn't top that. maybe i can run an internet campaign.
