Under Car light
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Jan 4, 2023.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I am looking for recommendations for a work light for doing work under the car. It needs to be bright with a wide display/ magnetic for sticking on things/ rechargable / have some kind of base for setting on the ground and pointing up/under 50 dOllars. Any suggestions would help.
    Thanks
  2. StarCaller
    StarCaller Senior Member
    1,282
    732
    Cedar Crest, NM, USA
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I work on vehicles often enough I should have an extensive setup but I simply use extension corded drop lights (with LED bulbs) and a small, cheap, rechargeable LED light (with magnetic base) from walmart/HF for the tight spaces. Having an extra 120v receptacle on the drop light for power tools really helps too. I too often leave battery lights on while not needing them (run to the parts store). Also, skip the finicky micro-usb charge ports if possible.
    Taxi/Limo likes this.
