Under dash lighting
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Kidd, Nov 22, 2007.
  1. Tideland Prius
    16,683
    oh alright. Lemme know when you get it done. I'd like to wire some lights to the rear footwell (I already have the front done).
  2. siliconhybrid
    siliconhybrid Member
    121
    Bay Area California
    what's the difference wiring light for rear footwell and the front?
    What I am going to do is to have all 4 lights comng from the same supply (there is the hub connector)
    I bought the costco cyron, I think I will try to find space for these sticks. They look great... you can change colors by having these Red-Green-Blue LEDs. I'll probably return the IKEA's
  3. Gadgetdad
    Gadgetdad New Member
    462
    Modesto, California
    There are so many possibilities with the Cyron unit. Do you know where to find the power lead to the dome lights to tap? Let me know if you make progress.
    Lee
  4. Tideland Prius
    16,683
    The difference? My fronts are JDM Prius footwell lighting... They plug directly into the dome light plug.
    If I were to add rear footwell lighting, it'll have to involve some splicing and since I'm not good with that sorta stuff, I was hoping to get yours and gadgetdad's experience/knowledge on this so I won't splice the wrong wire.
    I don't even know what a hub connector is
  5. moregas
    moregas New Member
    58
    Denver
    Here are some blue lights you could get soon...
    AutoblogGreen
  6. siliconhybrid
    121
    Bay Area California
    I may have time this weekend to at least start this project. I think I'll use the cyron version, if I can find a good space under the dash :) it is soo coool. I can set color that I want with the R-G-B combination. Right now I am experimenting if the color will stay at the last state (pause) after turning it off for at least 1 day, otherwise (if the color resets to green), I may have to reconsider, I don't want to keep changing the color setting.
    I will tap the supply from the cigarette lighter as I want to have full control when to turn on/off. I haven't looked, but you might want to see darell's evnut.com website for your dome light wire.
    Tideland, the hub is like a box for channeling out each LED. think of USB hub: 1 input, several outputs. The hub is provided when you buy cyron or IKEA's LED. I'm not sure if "hub" is the correct term.
  7. Tideland Prius
    16,683
    ohhhh okok. Yeah I see what you mean.
    So yeah I guess all I need is instructions on how to hook that up to the car. I'll probably use green to complement the JDM set. But I'll wait til it gets warmer to do the actual install.
  8. martinisaacanywhere
    martinisaacanywhere Supa Memba
    62
    I used this:
    LITEGLOW 7LEDXS 7-Color Accessory Kit
    and it's been awesome! It's pretty easy to tap wires and put in the switch that I used, here's the wiring out of the car before i put it in.
    Here's the octo connectors sitting under the cupholder in the center console.
    wiring
    and this is the final product:
    (sorry about the blur)
    ****See the switch in the top left corner of the pic??
    The whole thing cost 80 with the connectors, wires, switch and of course the lights. This is another great product from liteglow. Thanks to Darrell the EVNUT! for the advice about the switch! :)
  9. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    So, we added those LED lights to our sofa-thing:
  10. zacknolden
    zacknolden New Member
    Tonopah, Nevada 89049
    2001 Prius
    When the electronic dash lights up you know you're turned on.
    As with most hybrids, the gasoline engine shuts off when you're stopped, either in your driveway or at a traffic light. When you hit the gas pedal, everything comes to life and you can move away as with any other mid-size with a slightly underpowered engine. But the excitement of driving the Prius negates any complaints about low power. :eek:
  11. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    One question, for those that really don't care about multi-colors and such, couldn't some LED's just be put under the dash and connected to those wires in the dash lighting box? Of the three wires, which ones would you need to connect to?
  12. chrisspaulding
    chrisspaulding sexy, high tech, fun
    556
    24
    Kentucky
    Here is my VERY SIMPLE and CHEAP Under Dash OEM LED DIY
    LED STRIP(s)
    9v BATTERY(s)
    9v BATTERY HARNESS or BOX
    or [​IMG]
    ROCKER SWITCH
    Mix them all together(hidden behind the dash)...
    Badda bing - badda boom!
    No splicing your precious Prius 12v system. OEM/clean install!
    We all have empty switch housings on the left dash. Place the rocker there! BAM!
    Pics soon.
    c'mon. This is perfect for the non-electrician/chepo (like me)!
  13. Doc Willie
    1,717
    144
    Out there, somewhere
    So are you gonna do it? Sounds simple but once one gets into routing wires from one side of the dash to the other, finding mounting points, fitting things in between all the other stuff that is there, it can present . . . ahhh . . . difficulties.
    If you do make this mod, please write detailed instructions and pictures. If it works, I'll be right behind you.
  14. chrisspaulding
    556
    24
    Kentucky
    doing it this weekend.
    Positive it will be a good/clean install -easy and cheap.
    Might take a little time though, like going to Radio Shack and the install, but that's the fun part!
    report and pics by Mon. stay tuned! :cool:
  15. chrisspaulding
    556
    24
    Kentucky
    Dude, your MORE link is funny! In a cool, creative way. I think I figured out what most of them are. Nice!
  16. Sheepdog
    Sheepdog C'Mere Sheepie!
    1,125
    Sanford FLorida
    I like the idea of front and rear lights in colors. I will be anxious to see how you folks do it!
  17. chrisspaulding
    556
    24
    Kentucky
    I got this done over the weekend!
    Works perfect!
    My camera wouldn't pick up the blue light last night, so later today i will write up the instructions and take pics of the wiring.
    Stay tuned!
    p.s. This is such an easy install!!!!
  18. Chessie
    Chessie New Member
    DesPeres
    The Toyota Yaris has an LED foot well lighting option, would this work on a Prius?
    Since its a Toyota part it should also we covered under a Toyota warrantee if it goes out.
    C
  19. Doc Willie
    1,717
    144
    Oh d**n, now I'm gonna have to do it.
