Under the hook fuses and relays check
Discussion in 'Gen 3 Prius Technical Discussion' started by Drepdom, Feb 24, 2024.
  1. Drepdom
    Drepdom Junior Member
    2015 Prius 3, 155k mi. My simple question is if the battery negative or power in general have to be cut off to be able to remove or replace fuses (10A PCU, 7.5 P CON MAIN)or relays (DRL fog light) from the fuse box; or shutting down the car is enough?
  2. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    Just turn the car off /
  3. Drepdom
    Then I don't understand. With the veh off , I removed a add a circuit and added back the original drl fog light relay. So, when I went to turn on the car I got the.. look at the pics.. and I haven't been able to driver my car for almost a week.
  4. Brian1954
    Brian1954 Senior Member
    2,671
    1,068
    South Central PA, USA
    How old is your 12v battery?
    Measure the voltage of the 12v battery when the car is off.
    Do you own a 12v battery charger? Is so, connect it to the 12v battery and charge it up.
  5. Drepdom
    The battery is from 1/22 and I bought it on 12/22. It charges all the way up to 13.49v. But in about .30 min it drops to 12.4v
  6. Brian1954
    2,671
    1,068
    Did you measure the battery voltage before you charged it?
    Did you try starting the car after you charged the 12v battery?
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,074
    6,937
    Texas Hill Country
    Assuming the add a tap circuit was not necessary, the relay used may be wrong.
    To get better feedback add more details.
