Underbody coming undone
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by poonam316, Apr 27, 2013.
  1. poonam316
    poonam316 Junior Member
    Dallas, TX
    The plastic under the nose of my car has come undone and now hanging. Most likely due to scraping against parking curbs. If I push it up, the plastic does not scrap until I hit a bump where it will drop due to the scraping and continue to scrap. My question is will my warrantee cover the repair/ replacement of the under body plastic? If not, how much should I expect to pay to repair or replacement?
  2. gliderman
    gliderman Active Member
    751
    225
    There was a TSB on mine and I got it replaced. You might want to check and see if it applies to your build.
  3. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    It's costing me almost $200 to replace the driver's side front fender liner, the parts were in the $135 range, yeah I know I could do it myself, but I'm 70 and lazy.
  4. poonam316
    Dallas, TX
    Whats a TSB? Sorry I'm new to the forum... don't know much.
  5. ou812
    ou812 Junior Member
    40
    Technical Service Bulletin
  6. Mendel Leisk
    40,574
    It could be you're just missing a few of the fasteners. There's also a few 10mm bolts involved. The fasteners are overpriced at $3~5 per, but much cheaper than a replacement panel, as long as it's hanging together.
  7. Zeus661
    Zeus661 Junior Member
    36
    Don't hit curbs
