Underhood Fuse #30 Inverter and converter, what does it do? Can I tap into it?
Discussion in 'Gen 3 Prius Technical Discussion' started by abubin, May 23, 2020.
  1. abubin
    abubin Member
    188
    92
    Malaysia
    I am trying to install a angel eyes outer rim LED that takes very little power. I would like to have this light turn on whenever the car is in READY. After reading through few mod thread here, seems like best option is fuse #27. That fuse used 10A and is stated as inverter and converter. I would like to know what this does before tapping into it.
    Or can anyone tell me any other fuse that is suitable. It need to be HOT only at READY.
    Thanks.
    edit: made a mistake, fuse #27 is the one I am talking about.
    #1 abubin, May 23, 2020
  2. ASRDogman
    ASRDogman Senior Member
    7,506
    3,885
    It would be a better idea to use a slot that is not in use. Like heated seats?
    Depending on which package you have, you'll have some empty fuse slots.
    That's what I used for installing my cameras, and another for the extra usb slots.
    "IF" something goes wrong with the led's and it blows the fuse, you lose your inverter/converter.
    I don't think the car will run if they are gone. :)
    And you can use an inline fuse.
  3. abubin
    abubin Member
    188
    92
    Malaysia
    i am referring to the fuse box under the hood in the engine bay. Not the one under dash. It will be too much work (and messy) to pull wire into the dash.
    But you are right on the fuse being blown for the inverter/converter. Car will be dead.
    Anyway, what the inverter and converter fuse actually does?
  4. ASRDogman
    7,506
    3,885
    I guess it takes care of the inverter converter. :)
    There are empty slots in the box under the hood also. Fog lights?
    If you don't have fog lights, then you can tap into that. Just make sure you use the fused size.
    So that if the fuse blows, the wiring is protected.
  5. abubin
    abubin Member
    188
    92
    Malaysia
    I do have foglamp. However, the foglamp fuses are located on the inside fusebox.
    Can you point in the picture, which empty slot you are referring to?
  6. ChapmanF
    17,967
    As I've said in other posts now and then, the labels on Toyota's fuse boxes are about as useful as the ones in your Grandpa's fuse box. You know, where one of the fuses has "hall light" scribbled next to it, and turns out to be the hall light, the dishwasher, smoke alarms, and doorbell.
    If you are looking at the actual wiring diagram (more info), then you know what a fuse actually does. If you're not, you don't. Them's the rules.
  7. RRxing
    RRxing Senior Member
    2,542
    1,817
    NEPA
    For Future Reference...
    Ed Beaty likes this.
  8. ChapmanF
    17,967
    Again, that's Grandpa's fuse-box door, not the wiring diagram.
  9. RRxing
    2,542
    1,817
    NEPA
    Better?
  10. ASRDogman
    7,506
    3,885
    I don't see a photo. I have NO idea what your car has. Except fog lights, now.
    How often do you use them? You can still use that fuse.
    Take the cover off, look at the fuses, read what they are. If you see something that you don't
    have on your model, you can use that one.
    There is an excellent change that what the cover says it is, then that is what it is.
  11. ChapmanF
    17,967
    What the cover says is supplied by a fuse is ... pretty much all the time ... one of the things supplied by the fuse. ;)
    In this case, RRxing came through with the goods in #9 ... that is a good fraction of a 2010 wiring diagram manual. It's missing the front matter, harness repair info, overall diagram, location-and-routing section, and fuses/junctions/relays section. So it's a little more work to find a fuse you're looking for. But the one mentioned in #3 is in there (10A PCU, page 220), and if you follow it over to page 223 you can see it is one of those nice ones where what Grandpa said it's supplying really is the only thing it's supplying.
  12. RRxing
    2,542
    1,817
    NEPA
    I noticed a different fuse box configuration between the USA and Malaysia. Perhaps abubin has a JDM version.
  13. ASRDogman
    7,506
    3,885
    Each country probably has a slightly different configuration, that's why you have to check YOUR
    fuse box. From the diagram RRxing supplied this is what I would try. BUT, check YOUR fuse box
    cover and see if they match!!!!
    #4 S-horn No Circuit
    #7 H-LP CLN Headlight Cleaner
    #14 Mayday No Circuit
    #27 MIR HTR Outside Rear View Mirro Defoggers
    #35 Spare Fuses 30A
    #36 Spare Fuses 15A
    #37 Spare Fuses 7.5A
    (35,36,37 May not have electric connections,
    just a place for spare fuses)
