Underlying Cause of Head Gasket Failures?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rjparker, Jul 29, 2021.
  1. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    water pump impeller becomes loose on shaft car has no way to know
  2. Rmay635703
    Rmay635703 Senior Member
    2,704
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    3. Plugging indicates one or both of the following
    A) Poor EGR design
    B) oil/liquid tending to favor one path over another
    Bad EGR systems aren’t uncommon and if we don’t want to fix the EGR each cylinder having its own AFR, independent timing and coupled with sequential fuel injection now you can safely run with a failed egr all day
    Why is the head gasket failing there and the bolts loosening?
    LSPI micro detonation and incompressible liquids overload the weakest link (bolts) and LSPI erodes the gasket
    These conditions combined can coke up rings which make the condition worse.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    I tend to agree with this hypothesis. Just yesterday I heard from a Toyota mechanic who found a loose head bolt and corresponding head gasket leak. Makes you wonder about the thermal cycling argument and why Toyota added the steel and foam spacer on gen4 to keep cylinder temps more consistent. Knocking is clearly a Toyota concern even though some pundits here may discount it.
    The structure of the water jacket spacer (Source: Toyota)
    In order to achieve optimized cooling by means of the cylinder bore region, a water jacket spacer consisting of stainless steel and foam rubber has been adopted. This involves a foam rubber with a brand name of EXPAD being placed in the coolant passage at the bottom of the cylinder bore. This allows a large amount of coolant to flow over the upper part of the cylinder bore, which becomes very hot, and ameliorates knocking by raising the cooling effect. At the same time, allowing a smaller amount of coolant to flow to the lower half portion of the bore to maintain a high temperature. With these techniques, fuel efficiency is achieved by making the expansion factors of the upper and lower cylinder bore even, and piston action friction is standardized at a low level.
  4. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I have checked head bolt torque on a failed head gasket engine. That was not the cause
