Understanding Prime Reported MPG With EV Mode Capacity
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by tovli, Jul 29, 2023.
  1. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I have completed the test and believe the car's reported MPG in HV mode is totally bogus when battery SOC is anything other than ----% for the entire HV mode miles.
    My test:
    - 248 miles in
    - 34 "HV Mode" segments over 10 days,
    - always selecting HV mode at startup
    - eco driving mode,
    - AC on 75F, outside 90-95F,
    - Florida flat,
    - Suburban 1-3 miles at 45mph between lights,
    - starts with slight power region usage until close to speed limit
    - 2023 Prius Prime XSE
    - tires at 35
    - Filled when half tank used
    - Fillup: 5.091 gallons (at $3.889)
    - Delta SOC: -60% (100% ... 40% at fillup)
    Results:
    - The average of the 34 reported MPG at shutdown: 52 MPG
    - My calculated "HV Mode w/available EV mode charge" average: 43 MPG
    - $0.090 per mile cost for HV mode miles at $3.889 per gallon gas ($0.045 cost for EV mode miles)
    Methodology:
    - "HV miles" = Total Miles - (Delta SOC * Average EV Range)
    = 148 - (.6 * 45.8) = 221 miles
    - 221 / 5.091 = 43 MPG
    Evaluation of Reasonableness:
    - The average MPG for the first three fillups (HV mode ----% for all miles) of hours long highway miles segments was 45 MPG.
    - Only 10 of the 247 test miles were at highway speeds, with the remaining segments averaging 7 miles of stop and go up to 48 mph, so 43 MPG seems reasonable.
    Comments:
    - So glad this is done and I can return to EV mode driving -
    #21 tovli, Aug 3, 2023
    vvillovv likes this.
  2. Numtini
    Numtini Member
    91
    94
    Cape Schrod
    2023 Prius Prime
    XSE
    So it drew EV down to 40% for you at which point you abandoned the test? Interesting. I did a long HV test on vacation and it seemed to stabilize at 85%. However, there's never any guarantee with that kind of thing about whether it's stable because driving conditions make it stable or stable because the car is no longer drawing the battery down.
  3. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Yes, the purpose of this test being lots of short segments in HV mode was to compute cost savings of EV mode vs HV mode for my everyday around town trips.
    I won't get opportunity to test long HV segments with avail SOC until I can solve the new bike-rack need or a future vacay.
  4. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Maybe the car gauges will make more sense while in EV mode. At least I hope they will be.
    Me, if a gauge doesn't make any sense to me, I try to ignore it until it does start to make sense, if it ever does ... Some of them in the Gen 4 I still don't get, cest la vie.
    tovli likes this.
  5. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    While I am not trying for hypermiler status, I do try to limit the time in "power" on the eco meter as I drive, and obsessively record the end of the day SOC and total EV rate (mi/kWh) and the next morning record the charge from the wall (kWh and $) so I know how much to transfer to my utilities budget category, and to satisfy my desire to know/understand everything in my life (gave up understanding people)
  6. vvillovv
    4,336
    1,518
    NY
    One thing about Power mode that may be of interest and was described by @drash iirc? a few years ago is the the HVAC system stays engauged as opposed to cycling more when in ECO.
    It made a big difference for me when it's near or below freezing and the windshield would ICE up on the bottom 4 or 5 inches all the way across. Power mode seemed to get rid of a lot more moisture in the system and a lot less icing up. It may provide some benefit in hight heat and humidity too. You're in a much better place to see if that has any benefits to speak of.
    But you also have a completely new game to learn with your Gen 5, much like I experienced switching the Gen 3 PiP to the Gen 4 Prime.
  7. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I don't use Power Mode. I'm leaving it in Eco mode, with Eco AC (since I don't have to worry about ice on the windows :D).
    The "power" I was referring to is in the Eco arc above the vehicle speed. There are two green sections labeled "ECO", and two white sections labeled "PWR".
    I have found that starting up from a stop light with cars behind me, I need to accelerate with just a small sliver into the first PWR section. If no one is behind me, I will usually keep it just below the power section and take more time getting up to 45 mph.
    Today I went back to driving in EV mode. My average EV mode consumption rate is 4.3 mi/kWh, but as the above shows today I was in a bit more heavy footed, (and also needed serious windshield wipers).
    31.6 miles at 4.0 mi/kWh means I used 7.9 kWh of the available 10.6 kWh for EV mode. As a second method of calculating how much battery I used - the SOC reads 24% left so 76% of 10.6 kWh is 8.0 kWh so pretty close. My charger will pull from the wall 1.3 times the battery used, so tonight's charge will be roughly 10.4 kWh, cost $1.49, and take 7.5 hours. $1.49 for 31.6 miles at today's $3.889 per gallon is the equivalent of 82 MPG! Even being a little lead-footed I'm still feeling good about that.
    #27 tovli, Aug 3, 2023
    Blizzard_Persona likes this.
  8. vvillovv
    4,336
    1,518
    NY
    I wouldn't bother trying to explain how my mind works ( you might give up on discussion with me too).
    I realized after posting and reading the rest of your post #25 above, exactly what power portion of the gauge you were describing and also wanting to comment about how I document the gauges by taking pictures of as many of them as I can once a month (minimum). I've never counted how many there are, but there is a lot to say the least.
    I'll try to do better to keep on subject at hand since driving in EV is much more fun than driving in HV imo, anyways.
    I finally read all of your post #25 before writing this one. ( color me a bit embarrassed ATM).
    tovli likes this.
  9. Trollbait
    12,806
    The display software of the gen4 Prime was simply ported over from the hybrid model. In the hybrid % EV is simply time with the engine off. Toyota likely did the same with the gen5.
    The 50.3mpg is calculated over the entire 9.4 miles. Which is how it should be done. It is just that since this is hybrid software, it is ignoring any grid charge used.
    Storing Li-ion at 100% isn't good long term. HV mode usually holds the charge at whatever point it was at, but it sounds like Toyota could be letting it use some to bring a charge down to a point for better shelf life. 30% to 40% is the recommended point for storage, but the system could be taking ambient conditions and settings into consideration when driving in HV mode. Though self-discharging and vampire drains also are a consideration.
    In general, an electric motor is pretty efficient over its entire output. An engine's efficiency peaks at certain out puts. For cars, those efficient peaks are at the higher loads when at highway speeds. If gas is going to be burned, using it on the highway can be the best way to burn it. There is also the fact that the limited Ev charge on a PHEV will go for more miles at city speeds.
    #29 Trollbait, Aug 6, 2023
    tovli likes this.
  10. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    If I sum up the (miles times MPG) for my test I get an estimated 4.7 gallons of gas used for the 248 combined miles giving an average near 53 MPG.
    The actual fill was 5.091 gallons which again ignoring the grid energy used would give 49 MPG which is 8% lower. Not good but wait…
    If I don’t ignore the roughly 27 “grid miles”, then the actual consumption rate is approximately 43 MPG which is 23% lower than the average indicated making the displayed MPG in the Prime totally bogus.
    The prime appears to be able to measure battery power consumption extremely accurate ( +/- 1% ) but gas consumption only to -20%.
  11. Trollbait
    12,806
    Even in non-plug ins, the MPG display tends to be 'optimistic'. One agreeing with calculated mpg is rare. 5% to 10% better is more likely.
    tovli likes this.
  12. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    Yep , and if I may add, when my journey goes well above the EV range and there are hills then i the keep my EV range around 50% , then switch to HV , letting some place for regen braking to fill up the battery.
    Blizzard_Persona and GeoJ like this.
  13. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    I appreciate your participation, but hasten to suggest checking the topic of the thread.
    In this thread, I am hoping to understand the multiple ways the car reports HV mode Miles Per Gallon and find something in the Prime that approaches my 2009 Prius MPG indication which was never more than 4% higher than the average of the actual MPG.
    Because of the bladder tank, the car's MPG indication could appear to be wildly different, more and less, than the (miles-since-last-fillup / gallons-this-fillup), but on averaging these the indicated remained around 4% higher than the averaged actuals.
  14. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    The measurement's within 8%, as you computed. It's just not attempting to compute your 'if I hadn't depleted charge' estimate. That '-20%' is not measurement error, it's you comparing values of two different measurements.
  15. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Indeed, I expected to find the indicated MPG to be around 5% high similar to my 2009 Prius which was 4% high on average.
    Discovering the optimism to be 23% is frustrating, but perhaps just as single actuals were sometimes wildly different than the car's reported MPG in the 2009, I would need to perform this HV driving test multiple times and average the actuals. I like driving in EV mode too much to invest further in HV mode MPG testing. I was hoping the result would be closer.
  16. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Yes, I want the car to estimate the real, actual MPG not some "ignore reality" value. It is very convenient for the Prime Prius to use the non-Prime Prius MPG estimate, but it loses its value in the Prime (when there is EV charge available).
  17. Trollbait
    12,806
    The 23% is because the car display was programmed for an ICE car, and it isn't set up to handle two different fuel sources. So it ignores one. I don't think any manufacturer set up their PHEV, nor bifuel cars, to provide info on the two different fuels. Setting the car to HV mode should mean it doesn't draw the grid charge down too much, but that doesn't appear to be the case with the new Prius Prime.
  18. KMO
    KMO Senior Member
    2,026
    751
    Finland
    2023 Prius Prime
    The problem maybe comes from the inverted presentation. In other parts of the world you would be seeing l/100km and Wh/km.
    Each km you use some electricity and some fuel. Attempting to present distance 'per fuel' or 'per electricity' is futile.
    MTN likes this.
  19. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Some folks have reported that it does hold the SOC approximately on longer drives at highway speeds (manufacturer suggested optimization). I seem to be confusing the car with shorter drives in a suburban setting.
    Bottom line, I was trying to do a quick and dirty test to compare HV around town with EV around town. The car says, "no I'm still going to use EV because it is more efficient", and "the devs did not invest in writing a calculation for a non-usual use case."
    #39 tovli, Aug 6, 2023
    Trollbait likes this.
  20. tovli
    353
    276
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Came to that realization the hard way.
