Unexplained brake noises
Discussion in 'Generation 1 Prius Discussion' started by Iris_TheRainbow, Apr 26, 2026.
Tags:
  1. Iris_TheRainbow
    Iris_TheRainbow New Member
    27
    Illinois
    2003 Prius
    My 03's brakes have recently developed a noise on the front passenger side that I've not been able to explain so far
    When I'm driving normally, It makes a squeaking noise that happens once per wheel rotation. When I hit the brakes, there's a single loud squeaking noise when I hit the brakes hard enough to come to a full stop.
    I know its brakes because the bearing is fine, no slop, consistent force needed to spin the wheel.
    I'm planning to pull the brakes off when I replace the front shocks and springs to see if something is obviously wrong, but I know the pads have nearly 1cm of pad width, the rotors are smooth enough, though there's a couple fine grooves in the outer face. They don't appear to be warped either. I feel like I've lot a little brake force recently, but not much at all.
    Is there something specific I should look for here? I've not really experienced a noise like this in other cars.
  2. Iris_TheRainbow
    27
    Illinois
    2003 Prius
    I’ve got no idea why the noise was happening now. I took them apart, cleaned everything, greased everything, and put them back together. It stopped after that. There’s no obvious wear from anything rubbing that shouldn’t.
  3. ChapmanF
    19,060
    That's an effective repair method a lot of the time. I've even fixed couldn't say how many things with the simpler method "took them apart, did nothing, and put them back together". :)
    stg1navy likes this.
  4. ronlewis
    ronlewis Active Member
    1,061
    206
    texas
    2001 Prius
    I like the "do nothing until the problem reveals itself" repair method.
