Unintended Acceleration -- While Parking
Discussion in 'Gen 3 Prius Main Forum' started by evpv, Dec 29, 2010.
Thread Status:
Not open for further replies.
  1. Penny's Dad
    Penny's Dad New Member
    421
    46
    Orlando Fla
    Sooo...wanna sell your car?
    The problem with all of this is of course that this forum is extremely suspicious of those who would Hoax the Prius or misdirect personal failures to the car because about this time last year...a similar act occurred (remember the guy driving the prius down the freeway with the cop next to him yelling that he could not stop?)
    The timing of Your Friends complaint is pretty suspicious...about 1 year to the date of that other infamous hoax...Also "all those posts being liars" is still a representation of .0001% of all Gen III US Prius owners so it also appears to be a very small number of people claiming unintended accel. It is statistically insignificant and perhaps indicative of people who may have lied or may be mistaken but even if they were all correct you would by that basis be more likely to win the lottery or be thunderstruck than have your Prius Accell unexpectedly...In fact a friend of mine had the right front wheel come off his GM Escalade...it was practically new and I count 105 posts about similar issues with the Escalade wheel...wow imagine that happening at 70 mph...HMMM lets get all worked up about Escalade safety for the sake of those poor owners....
    My point is this...a statistically insignificant number of complaints coupled with suspicious timing is going to get your friend no sympathy on this forum and probably not scare any of us so why keep this thread alive? Are you trying to save anyone or just Punk us?
  2. DataWrangler
    DataWrangler Prius Owner (finally!)
    128
    West Houston, Texas
    The fact that the "engine kicked in and made aloud noise" is exactly the expected behavior in the case of fully depressing the accelerator instead of the brake.
  3. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    My friend hasn't even submitted his claim to the NHTSA yet because I just sent him the information on Monday. It's healthy to be suspicious and skeptical about this kind of situation. But at some point the amount of complaints and proof will force Toyota to take action, just like what happened with the ABS/Bump unintended acceleration. The people who complained about that would probably have been called bad drivers and liars too, until Toyota acknowledged the problem.
    I would encourage you to read the complaints:
    https://www-odi.nhtsa.dot.gov/complaints/index.cfm
    Step 1: Vehicle--> Search Selected Type
    Step 2: Year-->2010-->Submit Year
    Step 3: Select Make-->Toyota-->Submit Make
    Step 4: Select Model-->Prius-->Submit Model
    Step 5: Select Component-->Vehicle Speed Control-->Click "Select this box if you would like to see a full summary" -->Submit
    There are also complaints about unintended acceleration while backing up with the brake on, but I decided to only concentrate on the forward-moving parking problem, because that's what my friend experienced. Do a little reading, you might learn something other than assuming everyone is a bad driver and a liar.
  4. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Yep, except his foot was on the brake as he approached the parking stall and it never left the brake as he was pulling into the stall. He was going very slow, almost stopped.
    Other people experienced a similar surge of throttle over bumpy surfaces when they had their foot on the brake, so it is possible for this to happen.
  5. bisco
    52,739
    have you been living under a rock? toyota already investigated. nothing. the government investigated. nothing. nasa investigated. nothing. if it ain't broke, you can't fix it. your 'friends' situation is not going to change anything.
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Why didn't you say earlier that you were there and saw where his feet were as the event happened?
  7. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Going back to the Audi's UA problems in the 80's, and other incidents with UA problems in a variety of vehicles, the one common element found was that people actually believed they had their foot on the brake pedal when in fact they were pressing down on the accelerator. Toyota has proved this to be the case in countless examinations of "black boxes". So, sorry if the majority of us here express doubt because not one piece of evidence has been found outside of the "floormat wedged up against the accelerator" issue that points to a defect other than the driver's right foot.:rolleyes:
  8. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    OK, so your opinion is that nothing is wrong. I said the same thing before reading the NHTSA web site.
    Before Toyota did the recall for unintended acceleration over bumpy surfaces, were all of those people liars too? By your logic, there was no proof so there was no problem. How is this situation different?
    I haven't seen the published results of the NASA investigation, do you have a link?
  9. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It was not an unintended acceleration fix, but rather a lack of deceleration that kicked in when the car ran over rough roads and the brakes were not firmly applied. The software fix was to adjust response time during a deceleration event!
  10. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    He told me he was just parking the car as usual, the same way he's been doing for 30 years with no accidents. He said he had his foot on the brake, he said he modulated the brake as he moved slowly into the parking stall, he said he had almost come to a complete stop when suddenly the ICE revved up and the car surged forward.
    Read the NHTSA stories, people describe the exact same thing, including unintended accelation when backing down driveways using only the brake.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Weirder stuff has happened....
  12. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    That's what I thought too, until I read dozens of complaints on the NHTSA site. There was more going on than just loss of braking force. The cars were accelerating briefly.
  13. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    I was around during the Audi 5000 problems and I remember them clearly. The issue was the size and location of the pedals. There wasn't a huge brake pedal and small gas pedal like most cars have. And the brake pedal didn't stick out a lot more than the gas pedal. People were hitting them both at the same time, causing the unintended acceleration. Audi fixed the problem by changing to convential sizing and spacing. The Prius pedals seem to spaced normally, so that's not the problem here.
    The black box recordings work when the computer is functioning correctly. But what happens during a glitch? I read one of the complaints where Toyota told the customer the black box showed he applied the brake and throttle simultaneously more than 160 times. His comments were pretty funny.
  14. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    No offense to the original poster, but it's videos like this that really support the "coincidence" that all the reports seem to happen only "while parking".
  15. priushippie
    priushippie New Member
    330
    Pennsyltucky
    Back in the fall of 1971, I was at a drive-in theater with three other friends watching the movie "Woodstock" and consuming mass quantities of alcohol and weed. When we the movie ended I proceeded to pull out of the space when suddenly my foot slipped off the brake pedal and landed squarely on the gas pedal pushing it to the floor. The car a 1969 Cadillac accelerated out of control into several other cars. When the dust cleared nobody was hurt but the damage was severe. Looking back at the space we had previously occupied there were piles of beer cans on either side. This was an absolute case of unintended acceleration! True story!
  16. fuzzy1
    10,687
    I have direct, first-hand experience with an ICE surge in a very similar parking situation, about a decade ago with about a quarter century of driving experience. This experience very strongly colors my view of similar events.
    The differences:
    () The event was halted before any collision occurred;
    () The car was not my Toyota, but a very old manual transmission Honda;
    () It was resolved purely by reflex -- hit the clutch, and released / reapplied the brakes as if the tires were sliding on glare winter ice. No thinking was involved.
    If you would have stopped this in mid-event and asked about my degree of certainty of the situation, I would have bet a very large amount of money that my foot was on the brake, not the gas. But hindsight noticed two points of evidence to the contrary: () the engine surge calmed the instant I released the 'brake'; () when the brake was reapplied (and it did work correctly the second time), the pedal felt different, and it somehow had shifted itself to the left.
    Based on this event, and on the many odd statistics surrounding the events that happen to others, and the various studies of the Prius and earlier episodes, I now demand considerably more evidence before putting too much weight in these reports. Things needed to change my mind include:
    () Reports from drivers who released and reapplied the brakes, and the engine did not calm while the brake was released;
    () Reports of runaway ICE surges in manual transmission versions of cars with the same electronic throttle controls (only possible in models with choice of tranmissions);
    () A balanced age distribution of the statistics, not the current strong skew towards older drivers.
    This misrepresents the Prius brake system. While there is a computer control layer in there, Prius still has the same mechanical footpedal to hydraulic system found in other cars. In the event of computer failure, most able-bodied adults should be able to use brute muscle force to push right through that computer layer, the same way they must in a regular car or SUV when the brake booster suffers a complete power loss. My first decade of driving produced considerable experience with this due to engine stalls.
    I cannot say that all engine surges are driver error. But mine was. And based on the considerable evidence that has been publicized, I strongly feel any real computer glitch events are greatly outnumbered by, and hidden beneath, a vastly higher rate of human error.
  17. derkraut
    derkraut Member
    299
    28
    SAN
    "The black box recordings work when the computer is functioning correctly. But what happens during a glitch? I read one of the complaints where Toyota told the customer the black box showed he applied the brake and throttle simultaneously more than 160 times. His comments were pretty funny."
    Yup, I believe that was the "weirdo" over here in SAN driving east on I-8. It was pretty much proven that there was absolutely no problem with his Prius, and that he apparently deliberately "pumped" the brake and accelerator pedals alternately intending to get a bunch of money from Toyota.
    Anyway, let the black box tell the story. It's possible that there was a mechanical malfunction; but I'll put my money on driver error.
  18. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    How do you know from the complaints that the cars actually were accelerating?
    People could for example feel a momentary reduction in deceleration and believe it to be acceleration.
  19. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    No offense taken, I love watching stuff like that. There's no doubt people do crazy things and make mistakes.
    But it's a whole different story when the car does it to you. The Gen 3 Prius has already had a recall for throttle/brake glitches over bumpy surfaces. People are reporting unintended acceleration when they disengage the cruise control. People are reporting unintended acceleration when their foot is on the brake. At what point do we stop writing it all off as driver error and consider the possibility that there really is a problem? For me it was when it happened to a friend, and then reading all of the other complaints.
  20. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Did you spend a few minutes to read the complaints?
Thread Status:
