Unintended acceleration
Discussion in 'Gen 3 Prius Technical Discussion' started by bob waber, Jul 8, 2016.
  1. stormchaser
    stormchaser Junior Member
    Bournemouth
    Agree with above.
    Even my CT200h does this and it's normal. Mines basically a Prius underneath.
    iPhone ?
  2. bob waber
    bob waber Junior Member
    washington
    If I press the brake, the energy display shows the battery is still adding power to the wheels which fights against the brake, wasting energy!
    What moron would design a car like this??
    ALSO, it does this when the gas engine is NOT RUNNING.
  3. bob waber
    washington
    It does this with the gas engine OFF, how do you explain that? Does your car do this?
    52,847
    sounds like you got a dud. but maybe toyota has no idea what they're doing.
    mine doesn't do that, might be time for a trip to the dealer, while you're still under warranty.(y)
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Creep in EV? Yes. Why would it be any different?
    fuzzy1 likes this.
  6. ZeroTX
    ZeroTX Junior Member
    64
    Houston, TEXAS
    Seriously, questioning the hybrid design skills of Toyota? Hehe.... There's nobody that has got it more "right" or consistently so as Toyota, and frankly, I like Honda cars better overall.
  7. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    What "energy display"? If I press my brake in "D" with the car and engine stopped, ScanGauge shows battery current drops to the same level it does in PARK. Therefore no battery energy is wasted in that condition "fighting against the brake."
    Yes, of course the car creeps in READY in "D" with the engine stopped and brake released---just like every other automatic-transmission vehicle in its nearest equivalent to "READY." If it didn't, that would confuse and scare off potential owners during a test drive.
    fuzzy1 likes this.
  8. fuzzy1
    10,706
    Yes, mine does, ICE on and ICE off. But either way, my Prius' creep is weaker than the creep of dad's automatic Jeep.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Are you sure the arrows aren't reversed and power is being transferred from the wheels to the battery? Actually it turns from orange to green, so you can't miss that.
    If your car is doing adding power to the wheels at a stop and engine is not on, there's something wrong with your car. Take it to be looked at.
  10. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    Agree with the point you intended, but to be more literal, it's mathematically and physically impossible to "add power to the wheels" while they are stopped. Power is torque times speed, so if speed of wheels is zero, power to wheels is zero, no matter how large the torque. That doesn't mean it isn't possible to waste power attempting to turn stopped wheels---as most conventional automatic cars do, and a Prius hypothetically could with a specific malfunction.
    mmmodem likes this.
