Unlock all doors with fob
Discussion in 'Gen 3 Prius Main Forum' started by sbddude, Nov 10, 2012.
  1. sbddude
    sbddude Junior Member
    62
    Bay Area, California
    2013 Prius v wagon
    In the owners manual, there are instructions to set all doors to unlock instead of just the driver's door.
    I followed these instructions. Now all doors unlock with the smart key (grabbing the drivers door handle), but NOT by pressing the unlock button on he fob.
    Is there a way to unlock all doors by pressing the unlock button on the fob once?
  2. gliderman
    gliderman Active Member
    751
    225
    There may be, but I have not found it. It is not an option on TIS that I have found. Just have to push that button twice.
  3. PriBlack
    PriBlack Junior Member
    I wondered that aswell.
  4. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Try hitting the fob "Unlock" button twice in a short interval. That works in other Prius models.
    JeffD
    pichner likes this.
  5. pichner
    pichner Metallic Maniac #001
    66
    Minneapolis, MN
    I agree with the above, on my 2012 I just push unlock twice and that does the trick.
  6. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Yes, that's how my car is--check the customizations chapter in the owners manual (it may need to be programmed by the dealer--can't recall).
  7. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    I know on my new PHV that setting is changed in the nav screen car settings. Do you have nav?
  8. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Non-menu procedure from page 48 of 2010 (page 72 of 2013) hatchback Owner's Manual:
    (Did not copy and paste very well because of tables and button images so paraphrasing)
    Switching the door unlock function
    It is possible to set which doors the entry function unlocks.
    Turn the “POWER” switch off.
    When the indicator on the key surface is turned off, push and hold Lock and Panic buttons
    or for approximately 5 seconds.
    The setting changes each time an operation is performed, as shown below.
    (When changing the setting continuously, release the buttons, wait for at
    least 5 seconds, and repeat .)
    Also talked about in this Plug in Prius post found by searching on "Unlock all doors with fob" (second hit on search list). It sounds like Pressing and holding
    How to unlock all doors by touching drivers door outside? | PriusChat
  9. sbddude
    62
    2013 Prius v wagon
    The fob and door handle are independent. The door handle can be programmed by the user. The fob requires tech stream (dealer or otherwise).
    I was able to find a tech stream cable to borrow and got it done.
    Chazz8 likes this.
  10. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Good to know dbddude. I love the detailed info you get from Prius Chat members. Thanks.
    I also see that you were using the instructions from the Owner's Manual, so my previous post was not needed.
  11. Ragin Cajun
    Ragin Cajun Junior Member
    52
    16
    The fob doesn't need tech stream. Just push the panic and lock at the same time on the fob.
