Unlocking all 4 doors by touching the driver door? (smart key)
Discussion in 'Prius c Main Forum' started by DoPeY5007, Mar 13, 2013.
  1. Rob.au
    Rob.au Active Member
    955
    439
    Sydney, Australia
    i-Tech
    Yes, the instructions are on page 68-69 of the 2012 manual that I posted a link to earlier. You changed the default.
    A dealer can always do it for you, but there's no need. The instructions are in the same place as above. One thing though: if activated, the function is that if you open the driver's door within 45 seconds of turning the car off, all the doors unlock. If it's a longer time, nothing happens. Note you should always be able to open the driver's door from the inside... if it's locked, it should unlock by itself when you try to open it. Oddly this is the only automatic door lock/unlock function that cannot be changed via display audio, according to the manual
  2. norahs
    norahs Junior Member
    52
    Bay Area, CA
    Thank you so much for pointing out where it is. I've tried it several times so far but no luck.. maybe I'll doing it wrong?
    step 1. close all doors and switch "power" switch to ON mode.
    -ON mode is pressing the power switch twice? From what I gather from the manual it goes off>acc>on or ready with brake pressed.
    step 2. within 20 seconds, shift the lever to N and hold door lock switch 2(lock) for about 5 seconds then release.
    - I believe I wasn't able to shift the lever unless the brake was pressed. Is that right?
    step 3. when the setting is complete, all doors are locked then unlocked.
    -I haven't gotten this to happen
    any help would be so much appreciated!! What shift position should I be starting in?(some other change settings say to shift to P to change, so how could they start in P?)
  3. ThNaz
    ThNaz New Member
    I just re-programed my C to unlock all 4 doors when I touch the drivers door handle...now my wife won't be standing out in the cold when I am having a senior moment forgetting to hit the unlock button in the car as I am getting in. I followed novasquids directions and it worked perfectly...this is a great forum.
  4. MarcSmith
    MarcSmith Active Member
    471
    150
    Northern VA
    so simple..... worked on my 2010 as well...
  5. ChuckFinley
    ChuckFinley New Member
    I followed this in my new C3 and it worked the first time. It sure makes life easier with kids.
    Thanks for the instructions!
  6. Fauxknight
    Fauxknight Active Member
    210
    116
    I'm confused/curious as to what situation would require you to open the door while leaving the car in drive because it's too dangerous and you might not have the <1 second to change back from park to drive? Unlocking the door and swapping passengers is more dangerous with the car left in drive, which is why the default is to not unlock the doors in that situation.
  7. koipond
    koipond Member
    198
    39
    Can I say thank you? The fellows at the service center didn't have a clue and said it could not be done. Now in just five seconds I've finally got the unlock feature working like I always wanted. Bravo!
    SCH-I535 ?
    ztanos likes this.
  8. rollerguy
    rollerguy New Member
    Little Chute, WI
    Thank you everyone for posting this. My 2013 now unlocks all 4 doors when touching the driver handle with such a simple fix.
  9. MeetGeorgeJetson
    MeetGeorgeJetson Junior Member
    48
    33
    Woodstock NY, USA
    GENIUS------ Thanks so much, such a simple fix.
  10. dragonrand
    dragonrand Junior Member
    74
    22
    Springfield, MO
    Thanks! My Gen II was set to do that and it was driving me crazy on my new (to me) Gen III that it wasn't doing that.
  11. Nate the Skate
    Nate the Skate New Member
    27
    Houston, TX
    2014 Prius c
    Bumping up. I've noticed my 2014 Prius C will open all four doors if I grab passenger side door. Kind of makes sense as a gesture of chivalry. I'd prefer just to keep it simple and all four open all the time .
    Paul276 likes this.
  12. ztanos
    ztanos All-around Geek!
    3,329
    1,134
    40
    Cumming, Georgia
    You can change this setting. You can either have it do driver only, or all 4.
  13. Paul276
    Paul276 New Member
    Dover
    Tried this and it performed just like you said, displaying 4 doors open, but only the drivers door opens
Loading...
